Post by spondonchris on Mar 30, 2010 18:04:15 GMT 1
OK number one, are the German spec rd350lc exhausts 0 stamped with orange dot restricted or is that just the German 250 pipes ?
number two.....just finishing my bike im going to run Swarbricks and a standard airbox on 31k YPVS carbs, i was going to raise the needle a notch but im after a main jet size to go with as a starting point. Thanks for your help in advance guys.
Also while im here just a suggestion but is it maybe worth putting a sticky up with all the stock jet sizes plus advisorys on....with microns fitted etc. I also have 4LO1 carbs and have no idea what the stock size is meant to be on them either lol. I have seen the jet guide on here but its too in depth i feel, just a basic guide would be usefull for members. Save a load of people puttin threads like mine on too haha.
Post by Tone on Mar 30, 2010 18:18:34 GMT 1
The standard sizes for the 4l001 carbs are
Main jet = 220 Jet Needle/Clip position = 5k1-3 Needle jet = P-2 Pilot jet = 22.5 Air screw (Turns out) = 1 and 1/2 Float Height = 21mm
Hope this helps. Tone.
Post by oldelsieboy on Mar 30, 2010 18:31:56 GMT 1
OK number one, are the German spec rd350lc exhausts 0 stamped with orange dot restricted or is that just the German 250 pipes ? Only pipes stamped 4L2 are restricted OEB
Post by spondonchris on Mar 31, 2010 11:00:19 GMT 1
Thanks guys any info on the 31k carbs appreciated or if anyone else has used this setup, 4lo350 engine. standard airbox, Swarbrick pipes, YPVS carbs.
Post by dredge3 on Mar 31, 2010 21:19:37 GMT 1
Do yourself a big favour...buy a Haynes. 31k0 main jet 240 air jet 0.7 jet needle 5K1 needle clip 4th groove from top throttle valve cutaway 2.0 pilot jet 22.5 air screw 1 1/4 turns out starter jet 80 float hight 21 fuel level 26 idle speed 1200 rpm
Post by spondonchris on Mar 31, 2010 23:08:56 GMT 1
Haha im not daft as a brush... but buying a YPVS Haynes for jet sizes would be a tad silly, thinking on i do have an LC350 one somewhere so im guessin the 4LO1 carbs info would have been in that. The exhaust info wouldent tho i dont reckon.
Post by spondonchris on Apr 1, 2010 0:12:09 GMT 1
Yea plug chops the only way in the end, christ im used to 1216 kits Flatslides and Gas flowed heads feel like im flamin 18 again messin with these things. Oh well i got a few engines to go at now in diffrent stages of tune so if i bang one its not the end of the world, think il shove the 250 engine in a go cart or summat hahaha.
