Post by pylwagl on Jul 25, 2024 23:46:30 GMT 1
So, do 350LC clocks mount on the top or the underside of the top yoke? I have found many examples of both arrangements on the internet but currently have mine on the underside, which looks correct to me. The reason I ask is that the routing of the clutch cable is very tight as it passes the speedo. The handlebars/levers appear to have correct orientation. If things are essentially correct, is it simply a case of jiggling it all about until it all fits better?
TIA Stu
Post by arrow on Jul 25, 2024 23:47:37 GMT 1
On the underside is correct. 👍
Post by 4l04ever on Jul 26, 2024 0:00:40 GMT 1
There is a wire clip which holds the clutch cable away from the clocks. A cable tie around the handlebars will work just as well.
Post by dodgyknees on Jul 26, 2024 14:41:33 GMT 1
Who is the guy that converts Kpm clocks to mph ?
foxy
Post by foxy on Jul 26, 2024 15:02:41 GMT 1
Shaun is the guy to go to regarding clock conversion
Post by dodgyknees on Jul 26, 2024 15:19:41 GMT 1
Shaun is the guy to go to regarding clock conversion What’s his name on here ?
Post by stusco on Jul 26, 2024 15:33:52 GMT 1
Shaunthesecond
Post by jon on Jul 26, 2024 15:44:17 GMT 1
If you have the headlight adjuster bracket bolted to the clock mount it only fits if the clocks are in the right place.
Post by donkeychomp on Jul 26, 2024 21:16:21 GMT 1
Don't worry...I screwed this up fist time...
