Post by Bozzy on Jul 22, 2024 9:24:01 GMT 1
Just after some advice.. you probably seen I went OTT with the three bond and decided to rip cylinders off again to do base gasket (glad I did).
So using new OEM base gaskets I have got some spray Hylomar M (non setting stuff appears to be all that's about). Thinking best to spray a thin layer of this on than using the grey three bond that quite thick or best to put a very think smear of three bond?
Thanks
Post by urbantangleweed on Jul 22, 2024 10:46:14 GMT 1
I use the spray hylomar, it's very good at sealing and comes apart easily when/if the time comes to dismantle in the future. Threebond is for metal to metal faces, not as a paper gasket dressing.
Post by midlifecrisisrd on Jul 22, 2024 13:43:39 GMT 1
I never use anything on ypvs genuine base gaskets and have never had an issue
Post by Bozzy on Jul 22, 2024 20:19:35 GMT 1
Thanks. Only reason was told main problem are for leak is the rear of the cylinder waterways so wanted to be 100%
Post by abar121 on Jul 23, 2024 16:53:19 GMT 1
I've never used anything on OE or Athena gaskets.
Post by urbantangleweed on Jul 23, 2024 18:09:02 GMT 1
Thanks. Only reason was told main problem are for leak is the rear of the cylinder waterways so wanted to be 100% Who told you that? There's no waterways through the base gaskets.....
Post by arrow on Jul 23, 2024 18:10:14 GMT 1
Thanks. Only reason was told main problem are for leak is the rear of the cylinder waterways so wanted to be 100% Who told you that? There's no waterways through the base gaskets..... That's what I was thinking too.
Post by vectisitch on Jul 23, 2024 18:19:24 GMT 1
Never use anything on the base other than a gasket. Last time I used 0.8mm gaskets from 4l04ever on here. My squish was 0.9mm and I wanted to raise it slightly by using a slightly thicker base gasket. Anyway I digress. His gaskets are a perfect alternative to oem.
Post by stusco on Jul 23, 2024 18:56:36 GMT 1
Im on 0.8 from4l04ever as well ,might be needing one unless ive got a spare
Post by Bozzy on Jul 24, 2024 8:27:54 GMT 1
Never use anything on the base other than a gasket. Last time I used 0.8mm gaskets from 4l04ever on here. My squish was 0.9mm and I wanted to raise it slightly by using a slightly thicker base gasket. Anyway I digress. His gaskets are a perfect alternative to oem. I was told prone to leaks rear of cylinder on Ypvs
Post by 4l04ever on Jul 24, 2024 11:38:31 GMT 1
I put a thin smear of grease on the base gaskets to allow easy removal in the future.
Post by reedpete on Jul 24, 2024 18:16:28 GMT 1
I put them on dry precisely because I do want the gasket surface to bond with case and barrel … it’s a good seal we are looking for after all! But for general applications it’s more of a personal preference what you do … most important at our age is that you can sleep well afterwards…. Don’t want to be pacing the house at 3.30am worrying if you should have done this or that !
Post by arrow on Jul 24, 2024 18:29:22 GMT 1
The clue is in the name; gasket. A gasket on its own is the all round package, fit for purpose out of the bag/box.
I have used sealant on damaged gaskets, but that was a long time ago.
Post by 4l04ever on Jul 25, 2024 1:59:43 GMT 1
A leak-down test will prove all your gaskets are good :-) No guessing and no stressing!
Post by arrow on Jul 25, 2024 2:03:41 GMT 1
A leak-down test will prove all your gaskets are good :-) No guessing and no stressing! That's good advice, but not that easy for people that don't have access to that type of kit.
