Post by archloafer on Jul 20, 2024 22:36:12 GMT 1
Hi all
Got a single blue spot caliper in combination with std 250LC master cylinder. Works OK, but does lack a bit in the way of feel. Had a look around and it seems a FZS Fazer 14mm one will work. Need the lever too, or will the LC one fit? What other options are there?
Cheers - David
Post by 4l04ever on Jul 20, 2024 22:43:14 GMT 1
14mm will make it more wooden. You need to go smaller than the 1/2".
YBR125 is the one you need. Get a good used OEM one. They should have 11 on the body as they are 11mm. Don't buy a cheap copy one as they as 1/2". Standard LC lever and mirror will fit straight on!
I use this setup on my LC. Lovely 2 finger braking :-) Using Bendix MF pads. Dot 5.1 fluid.
Post by archloafer on Jul 21, 2024 22:04:47 GMT 1
14mm will make it more wooden. You need to go smaller than the 1/2". YBR125 is the one you need. Get a good used OEM one. They should have 11 on the body as they are 11mm. Don't buy a cheap copy one as they as 1/2". Standard LC lever and mirror will fit straight on! I use this setup on my LC. Lovely 2 finger braking :-) Using Bendix MF pads. Dot 5.1 fluid. Good shout - thanks Rob. I'll see if I can locate one.
Post by rcgods on Jul 22, 2024 17:21:58 GMT 1
14mm will make it more wooden. You need to go smaller than the 1/2". YBR125 is the one you need. Get a good used OEM one. They should have 11 on the body as they are 11mm. Don't buy a cheap copy one as they as 1/2". Standard LC lever and mirror will fit straight on! I use this setup on my LC. Lovely 2 finger braking :-) Using Bendix MF pads. Dot 5.1 fluid. Good advice here! Searching for one for a silver spot caliper and thought I had seen a bargain at a tenner, however says 1/2" on the m/c not 11. Would not have known to look for that! Has a genuine looking cap on too.
