Post by fletche36 on Jul 19, 2024 15:40:31 GMT 1
Are there any issues when changing out the clutch pushrod seal (4l1)? Does the ball bearing stay in place when the rod is removed or should i work around it and just pick the old seal out? i have traced a very minor oil leak to that seal. Thanks.
Post by dusty350 on Jul 19, 2024 16:28:05 GMT 1
If you can lean the bike over a bit to the right hand side, you can remove the pushrod and then the seal - a "hooked" pick will do it. Leaning it over means the ball bearing and the oil dont come out ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by fletche36 on Jul 19, 2024 22:04:29 GMT 1
If you can lean the bike over a bit to the right hand side, you can remove the pushrod and then the seal - a "hooked" pick will do it. Leaning it over means the ball bearing and the oil dont come out ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Thanks.
