Post by lcmarky on Jul 12, 2024 10:18:34 GMT 1
50 miles yesterday and the rear just feels a bit low to me, so I've pulled the swinger off to raise the ride height.
I can get + 5mm on the Hagon lower mount & more than that I'll need to make a spacer to suit. It's M16 X 1.0 thread so simple enough to do.
I'm interested to know who may have increased their rear ride height and by how much?
Cheers Folks.
Post by lcmarky on Jul 12, 2024 10:20:33 GMT 1
Side on shot. I don’t want to go mad with the height, just up a bit.
Post by dougw on Jul 12, 2024 11:03:57 GMT 1
What static sag( no one on bike ) and rider sag ( rider in normal gear sat on bike ) have you got at the back ?
Just a thought, if the spring rate is too soft a spring change may be a better option.
Post by lcmarky on Jul 12, 2024 12:23:32 GMT 1
What static sag( no one on bike ) and rider sag ( rider in normal gear sat on bike ) have you got at the back ? Just a thought, if the spring rate is too soft a spring change may be a better option. Good questions. I have backed off the Hagon shock to give me ~ 10mm of static sag max. The spring is if anything stiff, but I can manage that a bit with tyre pressures. Definitely I do not want it stiffer, just a bit taller..
Post by urbantangleweed on Jul 12, 2024 12:37:32 GMT 1
Bike set up is of course a very personal thing, but for me, I like a bike with weight on the front, I get more feel from it that way so I tend to drop the forks through the yokes probably 10-15mm and raise the rear preload to give max 25mm rider sag.
Post by midlifecrisisrd on Jul 12, 2024 13:00:59 GMT 1
Hi
You will have lost 13mm going to a 17 inch rear wheel so adding the 5mm adjustment on the shock should take you back to standard
On builds where I've had NK rear end conversions I've used the 5mm raised shock mount AND the 5mm shock adjuster so +10mm
Another thing to consider is fork length. How much longer than standard (if any) are they
May make it feel ass down if the front end is higher
Post by lcmarky on Jul 12, 2024 14:39:35 GMT 1
Hi You will have lost 13mm going to a 17 inch rear wheel so adding the 5mm adjustment on the shock should take you back to standard On builds where I've had NK rear end conversions I've used the 5mm raised shock mount AND the 5mm shock adjuster so +10mm Another thing to consider is fork length. How much longer than standard (if any) are they May make it feel ass down if the front end is higher Steve Good points Steve.
Post by dougw on Jul 12, 2024 15:03:28 GMT 1
Smart phone protractor apps , "measure" on Iphone, are useful for quickly checking fork angles.
If I recall correctly a stock 4L0/1 was 27 degrees, prodie racer frames used to suffer "accidents" to get them a bit steeper.
I`m running around 24 degrees on the KTM EXC fitted with wets for tarmac hill climbs . (Sorry, but it is a two stroke and its bullet proof and crashes with minimal damage , unlike the LC , which will be getting some abuse at the next Curborough Twisty Sprint)
Post by lcmarky on Jul 19, 2024 18:53:13 GMT 1
+ 5mm on the shock mount and that's fine.
Post by lcmarky on Jul 19, 2024 18:54:25 GMT 1
Post by Tobyjugs on Jul 20, 2024 9:36:57 GMT 1
For your interest one RD which has been adjusted for track use, using standard 18 inch wheel is 480mm with static sag. measured from center rear wheel axle to center lower grab rail bolt. Fully extended 492mm
