Post by george on Mar 28, 2010 9:09:38 GMT 1
does anyone have a diagram of the clutch components? i took it off to put a new gear selector shaft in and whilst i have it all off i put new clutch plates and springs in but now i have put it all back together when i put the clutch mechanism side engine caseing on the plunger is miles away from the mechanism to push it even with the cable adjusted up to its fullest! i have the two little ball bearings in and i think i have put it back as it came off but just need to check i have done it correctly. any ideas?
Post by garyt on Mar 28, 2010 9:40:36 GMT 1
Post by george on Mar 28, 2010 9:57:05 GMT 1
looking at the diagram i have done it all right... why could it be so far away from the plunger???
Post by garyt on Mar 28, 2010 10:06:18 GMT 1
did you put part no20 in
Post by george on Mar 28, 2010 10:35:33 GMT 1
yes, as for as i can tell the mechanism has a ball in it which pushes the rod with has another ball at the other end of it which pushes part no.20 which pushes the clutch face...??
Post by george on Mar 28, 2010 16:58:49 GMT 1
there is no adjustments at all on the clutch basket side is there?
Post by george on Mar 30, 2010 8:14:50 GMT 1
thanks for that! someone had welded a washer on to the end of mine so i couldn't see it was adjustable! put a new threaded frd in and a nut on the end and works fine
