Post by steve99 on Jun 28, 2024 13:44:59 GMT 1
Hi all
Is the frame steering lock type on the UK RD350F1 the same as the German RD350LC?
I am trying to source a key so I can remove the lock for powder coating. I can see 4 numbers on the barrel front My German RD350LC key fits in the barrel but has 6 numbers on the key. I was hoping it would work but was a long shot!
Ideally I need the key type and where I can buy one
thanks in advance cheers Steve
Post by Yogi on Jun 28, 2024 14:37:40 GMT 1
Post by steve99 on Jun 28, 2024 16:01:09 GMT 1
Thanks for the information I just need someone who can cut the key to a number now
Post by Yogi on Jun 28, 2024 16:05:31 GMT 1
Post by steve99 on Jun 28, 2024 16:14:39 GMT 1
Thanks. I will as a last resort. Ideally if I can get a key then I would prefer that option
Now you have kindly told me the brand I have emailed a lock smith to see if they can help
Post by steve99 on Jun 30, 2024 21:17:44 GMT 1
My lock has 0141 stamped on it. Is this the key number or lock type? When I Google the number it appears quite a lot Cheers
Post by midlifecrisisrd on Jun 30, 2024 22:24:19 GMT 1
My lock has 0141 stamped on it. Is this the key number or lock type? When I Google the number it appears quite a lot Cheers I just had a Google and the 0141 was on a Laverda lock Another gut had a 4 digit code on the lock and a 6 digit on the key They are supplied with a tag with the numbers. Saw one on ebay that had 2 letters and 4 numbers I'd either drill it out or drill/tap a thread into it then fit a bolt and slide hammer it out Then buy a new lock Steve
Post by steve99 on Jul 1, 2024 7:47:52 GMT 1
Yeah I think itโs looking like the only option Thanks for the help
Post by Yogi on Jul 1, 2024 9:35:49 GMT 1
From memory I think you drill a 3mm hole at 2 oโclock after prising off the twisty cover
Matt ๐ถ๐ป๐ถ
Post by steve99 on Jul 1, 2024 10:58:55 GMT 1
Ok cheers
Post by steve99 on Jul 5, 2024 16:50:59 GMT 1
Now drilled out. The number on the face is definitely not the key number as a bought a key and it didnโt fit Thanks for the help
