Post by donegalad on Jun 21, 2024 8:45:44 GMT 1
Hi everyone.
I've a set of older carbs with 00 stamped on them. I've read in Haynes that a 3mm air bleed was drilled through the carb body to intersect with the air jet passage. Has anyone a diagram showing the location / direction of this 3mm hole.
Thanks
Post by oldelsieboy on Jun 21, 2024 10:09:16 GMT 1
Hi everyone. I've a set of older carbs with 00 stamped on them. I've read in Haynes that a 3mm air bleed was drilled through the carb body to intersect with the air jet passage. Has anyone a diagram showing the location / direction of this 3mm hole. Thanks rd350lc.net/4L0CarbTechSheet.pdfOEB
Post by donegalad on Jun 21, 2024 10:24:08 GMT 1
That's great. Thanks very much!
Post by shaunthe2nd on Jun 21, 2024 21:26:58 GMT 1
I did a post on this with pics too, but im on phone at mo and search function not so good, so cant find xx
