Post by archloafer on Jun 15, 2024 19:43:48 GMT 1
Hi all Trying to get the connectors out of the block so I can get a bit of heat shrink on the damaged rubber bit: ![](https://iili.io/d91epWX.jpg) Can't for the life of me see how they are clipped in - even with a magnifying glass. ![](https://iili.io/d91e2wP.jpg) I actually broke one of the wires in the process ![:(](//storage.proboards.com/forum/images/smiley/sad.png) Any help here greatly appreciated. David
Post by stusco on Jun 15, 2024 19:56:32 GMT 1
Post by Gitram on Jun 15, 2024 19:59:53 GMT 1
I got a set of the tools which you insert to pop the tang up on the more common bullets and blades, i think there are some which are circular that slide over the individual connector.. just nipped out to the garage to check and ... i can't find them.. could someone point me in the direction of the "safe place.."
marti
Post by archloafer on Jun 15, 2024 20:09:17 GMT 1
Post by stusco on Jun 15, 2024 20:12:33 GMT 1
Ive got the £21 kind its still tricky and sometimes they won’t come out , you can get a new connection here kojaycat.co.uk/ search rd350lc
Post by Gitram on Jun 17, 2024 11:01:23 GMT 1
Ive got the £21 kind its still tricky and sometimes they won’t come out , you can get a new connection here kojaycat.co.uk/ search rd350lc as Stu says.. i've got the sick squid ones.. somewhere.. possibly easier to get a new connector.. marti
Post by midlifecrisisrd on Jun 17, 2024 12:56:00 GMT 1
The problem when releasing any connector is that the barb has usually dug in or is tight against the end face of the receptacle
When you push the tool in it puts more pressure unto the barb
Once you get the removal tool over the pin pull back slightly then use something to push the connector in the direction it is fitted in to take the pressure off the barb then wiggle the extraction tool
Sometimes they just won't come out
Post by archloafer on Jun 17, 2024 17:55:41 GMT 1
The problem when releasing any connector is that the barb has usually dug in or is tight against the end face of the receptacle When you push the tool in it puts more pressure unto the barb Once you get the removal tool over the pin pull back slightly then use something to push the connector in the direction it is fitted in to take the pressure off the barb then wiggle the extraction tool Sometimes they just won't come out Steve Cheers I've ordered one of the Lisle tools, looks to be decent quality and should do the job. Also ordered a replacement grommet and some crimp terminals from Rex's speed shop. In the event I can't get them out and / or break the connector block in the process, I can get the 3-connector block from Kojaycat, as has been pointed out. The 4-connector block though? Rex's has this, which sort of looks right: www.rexs-speedshop.com/product/yazaki-4-way-female-connector/Thoughts on that? If push comes to shove I could get the opposing male connecter for the loom. David
Post by midlifecrisisrd on Jun 17, 2024 18:14:05 GMT 1
Post by archloafer on Jun 17, 2024 18:20:34 GMT 1
That does indeed look like the one - thanks!
Post by stusco on Jun 17, 2024 19:13:23 GMT 1
It has to fit through the hole in the casing best get the right one
