Post by chud786 on Jun 9, 2024 11:29:20 GMT 1
This is my first 250lc build. I've done a couple of YPVS but you don't need to set the timing on those. I haven't got the proper tool to set the timing so I came up with this. Will this get the timing close enough before I use a strobe to set it spot on? Can you see any problems I might have? Also it says in Haynes to set the timing to 2mm BTDC is this the best timing for a standard engine? Cheers timing
Post by abar121 on Jun 9, 2024 13:31:33 GMT 1
2mm BTDC works great for me.
