Post by donkeychomp on Jun 6, 2024 22:21:19 GMT 1
Anyone know the phone number? I need an offset front sprocket.
Post by stusco on Jun 6, 2024 22:39:40 GMT 1
Anyone know the phone number? I need an offset front sprocket. Alex 01455 272799
Post by donkeychomp on Jun 6, 2024 23:15:39 GMT 1
(Doffs hat). Thank you sir.
Post by dusty350 on Jun 7, 2024 7:28:18 GMT 1
Try Talon first Alex Have you now measured for the offset ? ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by donkeychomp on Jun 7, 2024 21:05:31 GMT 1
Talon? Okay mate, thanks. Yes I found my long ruler and it's 10mm.
Post by dusty350 on Jun 7, 2024 22:04:20 GMT 1
Pretty sure Talon stock up to 9mm offset fronts. After that its made to order and price jumps up. ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by donkeychomp on Jun 7, 2024 22:08:35 GMT 1
Bugger. I've pinged them an email, see what they say. Found one in the States at $60 but I bet postage will be about $100 knowing them. But would 1mm make a huge difference?
Post by dusty350 on Jun 8, 2024 8:18:25 GMT 1
Talon will do them. Pretty sure it's where NK get them from anyway In reality, 1mm probably wont make any difference. Another option is to fit another locking washer behind the sprocket to pack it out, but you'll need to make sure you can get the lock washer onto the splines of the output shaft. The other thing to check is that the chain wont hit the inside of the frame rails above the swingarm pivot. You should be ok , but at 9mm and over for a front offset, it's getting close ! Double check the width of the rear sprocket too. Looks like a 520, which means it should be 6mm wide. ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by midlifecrisisrd on Jun 8, 2024 8:33:52 GMT 1
I reckon 1mm is nothing, will be a bigger tolerance between bikes from new
When I bought my 3hm1 rz250 it had an r1z250 rear wheel fitted and was 5mm out, you could see the wear on the front sprocket where it had been rubbing on the inside face
Post by Robbieben on Jun 8, 2024 9:28:27 GMT 1
Most manufacturers work on +/- 1.5mm on chain tolerance on modern bikes, older bikes were +/- 1.5-2.5mm depending on the manufacturer so at 1mm you should be fine ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by donkeychomp on Jun 8, 2024 21:17:43 GMT 1
Thanks lads. I did the sprocket measurements before trying NK...the rear is a 520, front 530.
Post by muttsnuts on Jun 9, 2024 16:48:25 GMT 1
I have offset sprockets on the shelf, will check size, think they are 5mm and 9mm off the top of my head, both are 520 chain
Post by dusty350 on Jun 9, 2024 17:48:17 GMT 1
Job Job'd !! ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by donkeychomp on Jun 9, 2024 21:19:41 GMT 1
Yay! PM sent.
ps rather keep all deals in the LC community than give a total stranger my hard earned...
Post by JonW on Jul 4, 2024 0:09:11 GMT 1
Last time I contacted Talon, they wouldnt sell these direct to the public and cited they only sold this product to certain distributors.
I'd defo contact Dave for these.
