ronnie2735
![*](//storage.proboards.com/forum/images/stars/star_black.png) ![*](//storage.proboards.com/forum/images/stars/star_black.png)
RD 250 LC 4L1 1981 Enjoyer RD is Currently broken down because of brake pads and spark plug cap
Post by ronnie2735 on May 24, 2024 10:53:09 GMT 1
Hello I need to change brake pads because theyre down to metal and have a few questions Right now im struguling to remove the individual pads. Is there any bolt going trough them in the caliper Replacement First of all im not shure if this is the original brake caliper (see picture) if this is the original must i use the original pads or is it possible to get some standart pads from a shop What are the specs of the original pads? Generall tipps I might have more quesrions, ill post them in this thread
link to Images (On flikr)
Thank you all very much for replys This forum and all of you have beed a huge help Lg ronnie
Post by chrisg on May 24, 2024 16:59:32 GMT 1
ronnie2735
Post by ronnie2735 on May 24, 2024 17:52:34 GMT 1
Thanks that helped alot I want shure wich pin was for the "bolt" but it turned out good For cleaning is brake kleaner okay for that, what woud you use? And there is that one metal aluminium pice on the back of the caliper how shuld you remove and replace this. Not the flat pice the other. Thanks for your help Lg ronnie
Post by steve63 on May 25, 2024 12:23:18 GMT 1
It looks like you or the previous owner got full value for money out of those pads 👍. The pin going through the pads can be very tight. I've stripped a few calipers where I have had to drift that pin out. It's easier to do with the caliper off the bike.
ronnie2735
Post by ronnie2735 on May 26, 2024 17:16:19 GMT 1
It looks like you or the previous owner got full value for money out of those pads 👍. The pin going through the pads can be very tight. I've stripped a few calipers where I have had to drift that pin out. It's easier to do with the caliper off the bike. Whait both bolts mus be taken out? The one with the mountig points and the one for the brakepads?
Post by JonW on May 27, 2024 2:01:34 GMT 1
The one big pin with the rectangular end.
Ronnie, its well worth getting a workshop manual for these bikes. Haynes is quite good and easily available, the OEM is also pretty easy to find since most Yam dealers ditched their copies over the years so they appear on ebay often.
Post by JonW on May 27, 2024 2:03:05 GMT 1
Post by JonW on May 27, 2024 2:05:38 GMT 1
A hot top for anyone working with an unfamiliar brake caliper is to look at pics of the pads that are fitted to it. Ie. if you look at these pads... easy to spot that they are held in with a big middle pin/bolt etc. ![](https://i.ebayimg.com/images/g/GJkAAOSw2eFh9tYq/s-l400.jpg)
Post by steve63 on May 29, 2024 19:05:47 GMT 1
It looks like you or the previous owner got full value for money out of those pads 👍. The pin going through the pads can be very tight. I've stripped a few calipers where I have had to drift that pin out. It's easier to do with the caliper off the bike. Whait both bolts mus be taken out? The one with the mountig points and the one for the brakepads? To remove the post you just need to remove the one with the rectangular end.
ronnie2735
Post by ronnie2735 on May 31, 2024 8:00:28 GMT 1
Metal thing how do you remove and replace this metal thing, dont know what the name is? it sits at the rear of the caliper on the "roof"
the caliper can you pull the second pin / bolt out without bleading the brakes? the whole brake is very dirty
Post by midlifecrisisrd on May 31, 2024 9:00:51 GMT 1
Is it just me that is uncomfortable with this 😬🙈
ronnie2735
Post by ronnie2735 on May 31, 2024 9:13:22 GMT 1
Is it just me that is uncomfortable with this 😬🙈 Steve what do you mean?
Post by midlifecrisisrd on May 31, 2024 9:25:01 GMT 1
Is it just me that is uncomfortable with this 😬🙈 Steve what do you mean? I'm a grumpy old man and worry about safety items on bikes, that's all Steve
ronnie2735
Post by ronnie2735 on May 31, 2024 10:10:54 GMT 1
I'm a grumpy old man and worry about safety items on bikes, that's all Steve Sorry i dont want to come of as Rude i was not sure what you ment
rn since i baught the bike i made around 7500 km and i dont know when the last owner did a service so i will bring the rd to the service when it runs and brakes again
thanks for your concern
Post by Robbieben on May 31, 2024 10:13:11 GMT 1
Everything can be done with care and a bit of knowledge. Do you have a Haynes or Climer workshop manual for the bike? Do you have a friend local to you that has experience of doing jobs like this that can show you how it is done this time to help you in the future? If the answer is no to the above questions I'd suggest seeking some help as your question tells me you don't yet know what you are doing.
ronnie2735
Post by ronnie2735 on May 31, 2024 10:31:57 GMT 1
Everything can be done with care and a bit of knowledge. Do you have a Haynes or Climer workshop manual for the bike? Do you have a friend local to you that has experience of doing jobs like this that can show you how it is done this time to help you in the future? If the answer is no to the above questions I'd suggest seeking some help as your question tells me you don't yet know what you are doing. i have the hayenes maual
your right im new to this, i have a few friends that worked on 50 cc sachs and puch mofas but not on real bikes.
Post by Robbieben on May 31, 2024 11:17:33 GMT 1
You're in the right place for help and advice as everyone on here is extremely helpful but sometimes hands on experience working with you when required is far better.
Post by chrisg on May 31, 2024 15:40:13 GMT 1
Once youve changed the pads, do you know anyone that could check the youve put it all back correctly. Fresh pair of eyes often helps.
ronnie2735
Post by ronnie2735 on Jun 1, 2024 17:28:13 GMT 1
Once youve changed the pads, do you know anyone that could check the youve put it all back correctly. Fresh pair of eyes often helps. I will do that I got the new pair right here i just need to know how you remove and replace this mrighe type metal thing that goes on the roof of the caiper
ronnie2735
Post by ronnie2735 on Jun 1, 2024 18:27:57 GMT 1
Once youve changed the pads, do you know anyone that could check the youve put it all back correctly. Fresh pair of eyes often helps. I will do that I got the new pair right here i just need to know how you remove and replace this mrighe type metal thing that goes on the roof of the caiper Sorry i was stupid my piston was all out and i had to push it back in thats solced the metal thing is now ealy replaceable Now just need to fit the pad in an get the bolt to the other side with is prety hard Learned something today Have a grate day
