Post by scootjockey on May 19, 2024 11:45:59 GMT 1
Ive got a TDR125 running 170 Athena and AEB high compression head and just bought a 32mm UMA PWK. Im waiting for a revised inlet manifold from AEB but stripped the OE 28mm carb and airbox off and offered the UMA with a Belgarda 4DL inlet manifold to see how they go and what room I don't have ...The carb just missed the radiator overflow tank near the rear shock and the carb top connections are totally different.
Does anyone know who or where I can get a custom throttle cable made (Still running standard Autolube) or parts to match the carb top and cable ? The standard 28mm Mikuni has a bent screw on joint affair where the UMA has a push in adjuster. I haven't looked as yet but can the standard cable be split and altered or is this a sealed unit.
Cheers Gaz
