Post by andy777 on May 18, 2024 23:21:41 GMT 1
I have a 250LC which has been converted to a 350 but still has the 250 rear wheel, will this still be ok to run.
will this cause any issues.
Thanks
Post by dusty350 on May 19, 2024 19:38:53 GMT 1
Hi Welcome to the forum. You can use the 250 wheel no problem. There will be plenty of 350 engined 250's running around with the original 250 wheel fitted. Most probably due to the high cost of 350 rear wheels ! The 350 has a better cush drive than the 250, which has the sprocket studs set into rubber filled cups, and you'll wreck them getting them out if they are worn out, and replacements are nla. In contrast 350 cush rive rubbers are readily available. Enjoy the forum Dusty ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
