Post by fletche36 on Apr 17, 2024 22:36:43 GMT 1
I have done a quick search and im still a little confused so ill ask here. If i fit a set of pwks do i just use the std cable or a ypvs cable? im aware i need a couple of angled tops . if i have to modify a std cable ill buy a non genuine rather than "modify" an expensive genuine one. Thanks.
Post by JonW on Apr 18, 2024 7:22:08 GMT 1
i assume youre fitting these on an LC?
I have them on a ypvs, using the ypvs cable... so not helpful. If i was using them on an LC Id expect the LC cable to work.. and If use an OEM, cos of the oil pump cable issues.
Post by fletche36 on Apr 18, 2024 13:59:36 GMT 1
i assume youre fitting these on an LC? I have them on a ypvs, using the ypvs cable... so not helpful. If i was using them on an LC Id expect the LC cable to work.. and If use an OEM, cos of the oil pump cable issues. Thank you sir.
Post by jessy03 on Apr 18, 2024 15:05:37 GMT 1
I’ve got them fitted to a ypvs and an LC, the ypvs was a straight fit the LC need 5mm cutting off the long adjuster nut.
Post by jessy03 on Apr 18, 2024 15:09:17 GMT 1
Post by fletche36 on Apr 18, 2024 15:30:38 GMT 1
I’ve got them fitted to a ypvs and an LC, the ypvs was a straight fit the LC need 5mm cutting off the long adjuster nut. Thanks, thats easy enough.
