hexta
Post by hexta on Apr 14, 2024 15:03:40 GMT 1
Hello, any recommendations on steering damper for this combo? Also, I haven't fixed the stops, would that be necessary if steering damper is installed? Thanks H
Post by dusty350 on Apr 14, 2024 18:25:21 GMT 1
I would get the lock stops done correctly if it were mine. Worst case -people do remove the originals, and drill through the bottom yoke and fit cap head bolts to act as new stops. Rgv bottom yokes are nice and flat so that works ok. The bigger forks will restrict lock over standard, but you will have to measure carefully to make sure whatever damper you buy will allow full lock (some dont coz they are too short !) I wouldn't personally rely on the damper alone to restrict your lock.
