hexta
Post by hexta on Apr 14, 2024 14:55:56 GMT 1
Hello I am currently running the Talon 17t offset sprocket and 39t rear but want lower gearing, say 15/39 or lower. Can't find 15t offset sprocket, could 44t+ rear be an option? Will likely need a longer chain. Or cut and weld together an old stock sprocket to a 15t I already have Thanks, H
Post by midlifecrisisrd on Apr 14, 2024 16:04:39 GMT 1
I'm running 17/41 with a 17 inch wheel
I wouldn't go lower
115 on the rev limiter in top
If you go to 44t it will be 8 - 9000 rpm sitting on the motorway
hexta
Post by hexta on Apr 14, 2024 19:29:05 GMT 1
I'm running 17/41 with a 17 inch wheel I wouldn't go lower 115 on the rev limiter in top If you go to 44t it will be 8 - 9000 rpm sitting on the motorway Steve I prefer staying below 75ish, not really into high speeds. With current setup I hit 75 in 2nd, and I liked the shorter gearing with 15t Edit: Where I live maximum speed limit is 90km/h, around 55mph Edit edit: 62 in 2nd is more like it๐
Post by lcmarky on Apr 15, 2024 8:30:05 GMT 1
What swinger do you have as a smaller front sprocket may cause interference issues?
A larger rear has the benefit to do the opposite and take the chain run away from the swinger.
I'll check my hybrid gearing as it feels about right, but I am running a 17T front.
