Post by masonmart on Apr 13, 2024 20:41:37 GMT 1
Owing to my inexperience on the Yams I have got into a position where I'm unsure. I'd had the barrels off to fix damage in the barrel from a stud and putting them on again I got into a tizzy with the half clamps on the YPVS shafts between the cylinders. Is it correct for the valves in each cylinder to be aligned and clamped in the same position not out of phase like the pistons?
Post by midlifecrisisrd on Apr 13, 2024 20:59:11 GMT 1
Valves should be at the same height regardless of piston position
Post by masonmart on Apr 13, 2024 21:40:03 GMT 1
Yes, because it's based on rpm? Many thanks
Post by reedpete on Apr 13, 2024 21:56:15 GMT 1
Yes correct, position is based on rpm and they don’t oscillate or reciprocate… just move to provide variable exhausts port timing.
Post by abar121 on Apr 14, 2024 20:01:06 GMT 1
Check for play / wear and also that they are perfectly aligned when wide open.
Post by urbantangleweed on Apr 14, 2024 21:48:03 GMT 1
Inspect the ends where the clamp goes, they should both be a D shape when viewed from the end but the flat part wears, one side becomes rounded off and causes all sorts of bother.
If they're both still good, a new centre clamp should sort it.
