Odd case
Apr 5, 2024 20:16:56 GMT 1
via mobile
Post by Bozzy on Apr 5, 2024 20:16:56 GMT 1
Hi bot worried notice today that the stamp on the bottom of the motor cases says Y-1 29L00 is that a 250 case ?
Top of case is stamped 31k_00 and is not dodgy proper stamp see it's not been messed with
Is this possible? It's a 350 was putting good power out 65hp ran great
It's worried me a bit
Oh motor dont Match frame but both motor number and frame is all on v5 and MOT etch for 10 years
What you find when striping the motor never knew number on bottom of case!
Post by dusty350 on Apr 5, 2024 20:23:13 GMT 1
No need to worry. The part numbers for the 31k cases start 29l
Post by 4l04ever on Apr 5, 2024 20:23:35 GMT 1
Just make sure the hand-etched numbers behind the stator match the top and bottom casing and you are good to go!
Odd case
Apr 5, 2024 21:24:39 GMT 1
via mobile
Post by Bozzy on Apr 5, 2024 21:24:39 GMT 1
Just make sure the hand-etched numbers behind the stator match the top and bottom casing and you are good to go! Thanks panic over yes they match Any hints to get the stained ally clean without shottblast taking ages with autosol
Post by 4l04ever on Apr 5, 2024 21:30:15 GMT 1
Aqua Blasting
Post by dusty350 on Apr 6, 2024 6:57:22 GMT 1
+1 on aqua. Nothing else gets them so good
Post by urbantangleweed on Apr 6, 2024 7:11:35 GMT 1
Nothing comes close to the finish and cleanliness someone who's good with an aqua blaster can achieve. I had these done recently by my local chap.
