Calum
Smokin
Post by Calum on Mar 29, 2024 12:49:12 GMT 1
Hello all, Hoping someone can give me some guidance on this. I've tried searching, but you either get far too many hits with regards to builds or conversions. I'll try and keep this brief.
I'm looking to build an RD350 31K engine from scratch and use build an Athena 421 cylinder conversion.
My question is, what parts do I need to do this.
I want to use the Banshee 350 crank cases, as these can be had brand new.
I am assuming this is all I need for the engine component list.
My question is, is there anything I am missing. I plan on using Banshee 350 crank cases, but am I okay to use RD350 YPVS 31K parts for everything else? Transmission/Clutch Basket/Misc Gears.
Edit: **Pinning Useful Links for Future Reference**
Post by JonW on Mar 29, 2024 12:52:50 GMT 1
Also... pistons for +4, carbs/filters, pipes, ignition, head work, rad.... etc etc
Calum
Smokin
Post by Calum on Mar 29, 2024 13:00:34 GMT 1
Hi JonW , Yes the pistons are included in the big bore link. Pipes/Ignition/Radiator will be made to suit as it's not for an RD chassis. I'm not sure what I want for carbs yet, I don't want big/big power. I just don't want to run YPVS for both cost/complexity of build. I have read that some ran stock 26mm carbs from their 350 to the 421. I was thinking more along the lines of two 28mm Flat Slides. The fuel tank on the bike isn't huge and I don't want too much power.
Head work I'll leave to a specialist as that's out of my skill set.
Post by JonW on Mar 29, 2024 13:30:51 GMT 1
Calum
Smokin
Post by Calum on Mar 29, 2024 13:36:32 GMT 1
Okay, brilliant thanks JonW . I guess my main point of concern is, I am okay to use the Banshee 350 crankcase with all 31K running gear right?
I am already the first paragraph in and feel like this is going to be a good read. This ought to be archived.
Firefox has a great "Text Only" mode which clears up the erroneous HTML page.
Post by headcoats on Mar 29, 2024 13:46:57 GMT 1
You can use ypvs crankcases if they have that wider seal area at the front Don't know which particular models though
Post by LC_BOTT on Mar 29, 2024 14:07:47 GMT 1
Calum
Smokin
Post by Calum on Mar 29, 2024 14:19:43 GMT 1
LC_BOTT Perfect thanks. JonW Perfect read thanks. That article was basically what I was looking for. By the sounds of it, sourcing the bits independently isn't the way to go and I should probably speak to my builder as they have offered to source all the bits and assemble the engine. Your article reaffirms this. They also build these engines day in day out and have just done my brothers build. So again rings all the right bells. I was just looking to spread the costs a little, but sounds like this could cause more hassle than it's worth.
Post by LC_BOTT on Mar 29, 2024 18:30:04 GMT 1
I went the opposite way and tried to source everything as cheaply as possible Not so easy at the moment, but depends if you are prepared to wait for things to become available. Saying that, its probably been 5 years since I started buying parts. You will definitely be finished before me too.
Post by midlifecrisisrd on Mar 29, 2024 19:20:50 GMT 1
Post by muttsnuts on Mar 31, 2024 19:25:53 GMT 1
banshee cases have the wider frontal area
Building one from scratch isn't hard, but knowing exactly what parts are needed, is less obvious
I build loads for people and each one ends up with some tweak or other, unless you have access to a lathe and stuff, you'll end up either hitting issues or farming out some jobs to companies that can do the work, there are a good few "gotchas" as well that you need to navigate if doing it for the first time
Also, depending upon which way you build it up, you need to make a careful note of or port timings etc and other engine parameters like squish clearance etc as you'll need that to design some pipes to meet your criteria unless you have access to some test pipes or pipes that are known to work with your engines setup
You will also need a programmable ignition (ideally) and you need to decide how you are going to time your engine up allowing for the extra 4mm stroke as that changes the timing etc
Calum
Smokin
Post by Calum on May 2, 2024 14:33:25 GMT 1
JonW I hope you don't mind, but navigating wayback machine is a bit of a faff. I've re-hosted your blog on my website (which is kept backed up), and set it to text-only mode for ease of reading. dt125r.co.uk/assets/uploads/files/YamahaRDYZUpgrades/Yamaha%20RD%20&%20RZ%20upgrades%20-%20RZ350%20RD350%20Big%20Bore%20Primer.htmlIt's a really insightful blog and I've decided just to build the engine from scratch using parts I can find on the internet. So far I've got the gearbox, selector drum, flywheel, clutch covers and an assortment of other parts. I'll look to get the cases next month and hopefully the stroked rods the next. Then the bottom end should be able to be assembled to some degree and I will order the cylinder kits and a local shop near me has agreed to do the machine to 421, they've done my brothers and quite a few others. Thanks again for all your advice people!
Calum
Smokin
Post by Calum on May 2, 2024 14:33:42 GMT 1
Post by JonW on May 2, 2024 14:49:54 GMT 1
JonW I hope you don't mind, but navigating wayback machine is a bit of a faff. I've re-hosted your blog on my website (which is kept backed up), and set it to text-only mode for ease of reading. dt125r.co.uk/assets/uploads/files/YamahaRDYZUpgrades/Yamaha%20RD%20&%20RZ%20upgrades%20-%20RZ350%20RD350%20Big%20Bore%20Primer.htmlIt's a really insightful blog and I've decided just to build the engine from scratch using parts I can find on the internet. So far I've got the gearbox, selector drum, flywheel, clutch covers and an assortment of other parts. I'll look to get the cases next month and hopefully the stroked rods the next. Then the bottom end should be able to be assembled to some degree and I will order the cylinder kits and a local shop near me has agreed to do the machine to 421, they've done my brothers and quite a few others. Thanks again for all your advice people! No worries Callum.... A thought: You might want to add some text at the top to say that this is lifted from my old 2smoked.com website and that you have my permission to rehost it... also its worth mentioning that the prices are old, I wrote that 10 or so years back. Good luck with your build.
Calum
Smokin
Post by Calum on May 2, 2024 14:59:41 GMT 1
Added a note to the top of the blog post. (Empty cache and refresh)
