Post by george on Mar 22, 2010 17:36:31 GMT 1
when i press the rear brake it bounces up and down, does this mean the drum/wheel is warped? what should i do about it?
Post by carlos on Mar 22, 2010 17:46:15 GMT 1
Yup, it's oval'd
Second hand wheel is one way to go, but how do you know what you're buying is any better?
I don't think you can have them skimmed as it'd end up too thin!
It may be worth taking the wheel off and inspecting for any bits of brake shoe etc if you haven't had it apart for a while!
Post by george on Mar 22, 2010 18:23:48 GMT 1
i have inspected the shoes already and they look fine because i had to have my tire re seated because it was wonky! i thought this was why the brake felt funny but its still doing it now the tires right!
Post by carlos on Mar 25, 2010 22:20:20 GMT 1
What bike is it?
Post by dredge3 on Mar 25, 2010 23:47:19 GMT 1
I have a spare 250lc wheel. coated black . mint other than wheel bearing housing is a bit slack.oh and its been left out in rain. You can have it
Post by george on Mar 30, 2010 8:18:20 GMT 1
oh thanks! how bad is the bearing holder? im looking for a decent one because i plan to have both wheels powdercoated.
Post by dredge3 on Mar 30, 2010 17:47:47 GMT 1
It lookes mint as its newly powder coated.The bearing is loose, so something would need to be done with it. What, I dont know.Shim it out?The bearing pushes in by hand instead of tapping in
Post by sidney on Mar 30, 2010 20:49:52 GMT 1
u could try and use a dot punch and punch all around where the out side of the bearing sits this will make it fit nice and snug it could be called a bodge but it works hope this mite help
Post by dredge3 on Mar 31, 2010 21:21:09 GMT 1
Its not an even fit all round doing it that way
