Gear oil
Mar 16, 2024 13:06:49 GMT 1
via mobile
Post by simonlc on Mar 16, 2024 13:06:49 GMT 1
Did I hear it’s best to use an old school mineral oil for the gearbox as it’s better for preventing clutch slip?
Post by oldelsieboy on Mar 16, 2024 14:02:02 GMT 1
Did I hear it’s best to use an old school mineral oil for the gearbox as it’s better for preventing clutch slip? Just make sure whichever oil you choose it conforms to JASO MA2 spec. OEB
Post by arrow on Mar 16, 2024 14:09:04 GMT 1
Did I hear it’s best to use an old school mineral oil for the gearbox as it’s better for preventing clutch slip? Just make sure whichever oil you choose it conforms to JASO MA2 spec. OEB There are some excellent gear oils around. As long as it's that spec. then mineral or synthetic will both work perfectly. MA2 is for wet clutches. 👍
Post by arrow on Mar 16, 2024 14:19:01 GMT 1
You could use one of the dedicated light gear oils made for the job. Don't be put off that it's probably 75/80 weight. It's equivalent to a 10/40 engine oil. Gear oils are measured on a different scale to engine oils, that's all.
Post by stirling11 on Mar 16, 2024 14:43:16 GMT 1
As the clutches in our bikes are generally 99.999% wet, then it’s advisable not to use any oil that has friction modifiers in it as your clutch will slip, like most multigrades for cars
The same oil has to lubricate the crank and gear box, the gear box is the primary source of oil degradation due to the shearing of the oil on the gear cogs, that same oil also has to lubricate the crank which has different effects on the oil
It probably doesn’t matter what brand you use as long as you understand it’s correct usage
Lots of discussion of the best oil to use is on here somewhere
For that reason I’ll keep the oil I use nit
Post by arrow on Mar 16, 2024 14:55:42 GMT 1
Just to be clear, on the LC the gear oil lubricates only the r/h main bearing on the crank, as well as all the other gearbox parts. 👍
Post by 4l04ever on Mar 16, 2024 16:10:01 GMT 1
I always use Comma Eurolite engine oil. Tested in racing ZX10R engines with no clutch slip.
Also, make sure you put at least 1.7 litres of oil in a new engine build. You can get issues with overheated 6th gear if too low.
Post by chrisg on Mar 17, 2024 17:45:06 GMT 1
