dex46
Post by dex46 on Feb 18, 2024 10:30:50 GMT 1
Hi all Iām currently collecting parts for a hybrid build for Frenchy front end is sorted picked up a complete VJ21 front end. Advice needed on the rear wheel is there an alternative to the VJ22 17 inch rear wheel from another Suzuki due to the fact the VJ22 wheel seem hard to come by my plan is to use a Metchamex for a VJ22 rear wheel Thanks Dex
Post by midlifecrisisrd on Feb 18, 2024 11:49:34 GMT 1
I've used both gsxr400 and gsf400 rear wheels
The brake disc offset is different though you need a custom caliper carrier to work with the vj22 set up
I had a few made but the engineer I used has retired now
Personally I'd get a torque arm mounting point welded on the bottom of the arm when they make it and use the gsxr/gsf set up
The thing with hybrids is you will need to adapt bits as not everything will be plug and play
Will need sprocket carrier machining too
Post by JonW on Feb 18, 2024 12:58:53 GMT 1
The thing with hybrids is you will need to adapt bits as not everything will be plug and play Will need sprocket carrier machining too Steve 100%... and that's the huge fun of hybrids, ie solving the problems in building them. If its plug and play its boring really, its why many of us build different bikes every time.
dex46
Post by dex46 on Feb 18, 2024 13:30:01 GMT 1
Cheers have been looking at them two options šš Not ruled out a VJ21 rear but tyre choice is restricted
Post by midlifecrisisrd on Feb 18, 2024 13:51:33 GMT 1
I'm swithering whether to use an 18 inch rear on a future hybrid build. Think I need to scratch an FZ750 running gear build if I could find a front end
Bridgestone now do a decent 140 radial but let's face it a roadsides or BT46 would suffice
I started with a vj22 wheel but got rid of it over concerns about the brittle sprocket carrier. Will be no problem on an LC but on higher tuned stuff they broke around the sprocket mounts
Vj21 uses the same carrier
dex46
Post by dex46 on Feb 18, 2024 15:02:03 GMT 1
Cheers Steve šš Plan is to use metchamex for either 21 or 22 depending what wheel comes up
Post by dusty350 on Feb 18, 2024 15:42:05 GMT 1
I've got a spare 21 wheel and hub. I used a 21 in the Cafe bike build, and visually the spoke pattern is the same as the 21/22 front. I got Garry at Metmachex to make the swingarm for the 21's torque arm and brake set up as that is different to the 22's. This is Vj21 with a standard rear brake caliper, integral with the carrier; 20220312_161317 by dusty miller, on Flickr This is a 22 wheel, with a Tyga carrier and Brembo caliper -no torque arm as the carrier locates on a peg on the inside of the arm; 20220326_110018 by dusty miller, on Flickr
dex46
Post by dex46 on Feb 18, 2024 16:14:19 GMT 1
That was my plan to use tyga brake mount with the Brembo Metchamex now do an arm for either the 21 or 22 wheel Out of interest Dusty pm me a price please for 21 wheel and carrier as I might go down that route Dex
Post by badger1 on Feb 18, 2024 21:48:33 GMT 1
I'm swithering whether to use an 18 inch rear on a future hybrid build. Think I need to scratch an FZ750 running gear build if I could find a front end Bridgestone now do a decent 140 radial but let's face it a roadsides or BT46 would suffice I started with a vj22 wheel but got rid of it over concerns about the brittle sprocket carrier. Will be no problem on an LC but on higher tuned stuff they broke around the sprocket mounts Vj21 uses the same carrier Steve No need to worry about the carrier now. www.performancefab.co.uk/rgv250-cush-drive
Post by zig on Mar 12, 2024 11:52:26 GMT 1
I've got a spare 21 wheel and hub. I used a 21 in the Cafe bike build, and visually the spoke pattern is the same as the 21/22 front. I got Garry at Metmachex to make the swingarm for the 21's torque arm and brake set up as that is different to the 22's. This is Vj21 with a standard rear brake caliper, integral with the carrier; 20220312_161317 by dusty miller, on Flickr This is a 22 wheel, with a Tyga carrier and Brembo caliper -no torque arm as the carrier locates on a peg on the inside of the arm; 20220326_110018 by dusty miller, on Flickr nice alloy kicker then you changed it ?? or the other way around Dusty ?
Post by dusty350 on Mar 12, 2024 12:19:18 GMT 1
Different bike Zig. The first pic is the Cafe bike with the Tzr kicker, the second pic is the 400 hybrid with a standard but polished kickstart lever
