Post by 4l04ever on Dec 28, 2023 16:22:37 GMT 1
muttsnutsWhat standard/stock versions of Alonze pipes can be ordered?
Post by muttsnuts on Dec 28, 2023 19:15:59 GMT 1
Hi Rob,
generally on the shelf or within a couple of days from order, you can get
250/350LC mid range pipes - in mild steel with FIXED ally end can - S/S pipes are normally order only 250/350LC F2 performance pipe - in mild steel with detachable ally end cans 350 YPVS F2 performance pipe - in mild steel with detachable ally end cans
Hope that helps
Post by donkeychomp on Dec 28, 2023 22:19:05 GMT 1
That's good to know. I take it all the pipes will need some carb re-jetting?
Post by Tobyjugs on Dec 29, 2023 3:28:39 GMT 1
Hi Rob, generally on the shelf or within a couple of days from order, you can get 250/350LC mid range pipes - in mild steel with FIXED ally end can - S/S pipes are normally order only 250/350LC F2 performance pipe - in mild steel with detachable ally end cans 350 YPVS F2 performance pipe - in mild steel with detachable ally end cans Hope that helps Do you get many requests for a 250cc specific set of pipes.
Post by liffy16 on Dec 29, 2023 11:09:25 GMT 1
Have got the mild steel mid range on my 250lc didn't need to rejet after plug chop,don't think anyone does 250 specific pipes?
Post by 4l04ever on Dec 29, 2023 11:41:24 GMT 1
Can you confirm the attached-can mid range pipes are just for LCs and not suitable for YPVS?
Post by JonW on Dec 29, 2023 13:06:09 GMT 1
Have got the mild steel mid range on my 250lc didn't need to rejet after plug chop,don't think anyone does 250 specific pipes? The Japanese have a lot of 250s, its considered (but not tested) that their pipes are 250 first and 350 second. But as I said, I dont think there are many tests of them.
Post by ferox100 on Dec 29, 2023 13:51:50 GMT 1
Any Dyno charts for the performance pipes for the 250/350 LC and also for the ypvs??
Post by liffy16 on Dec 29, 2023 15:10:22 GMT 1
Have got the mild steel mid range on my 250lc didn't need to rejet after plug chop,don't think anyone does 250 specific pipes? The Japanese have a lot of 250s, its considered (but not tested) that their pipes are 250 first and 350 second. But as I said, I dont think there are many tests of them. Yes agreed was referring to UK aftermarket pipes
Post by muttsnuts on Dec 29, 2023 21:07:21 GMT 1
Can you confirm the attached-can mid range pipes are just for LCs and not suitable for YPVS? correct Rob
Post by muttsnuts on Dec 29, 2023 21:09:34 GMT 1
Hi Rob, generally on the shelf or within a couple of days from order, you can get 250/350LC mid range pipes - in mild steel with FIXED ally end can - S/S pipes are normally order only 250/350LC F2 performance pipe - in mild steel with detachable ally end cans 350 YPVS F2 performance pipe - in mild steel with detachable ally end cans Hope that helps Do you get many requests for a 250cc specific set of pipes. not too often, but I have thought about seeing how much better I can make the mid range ones for 250's specifically, problem as always is time with me, too many things on the go and also having to run a business means my "free/play" time is very limited
Post by midlifecrisisrd on Dec 29, 2023 21:09:43 GMT 1
Is that cause a YPVS already has a midrange 🤣
Post by muttsnuts on Dec 29, 2023 21:12:33 GMT 1
Any Dyno charts for the performance pipes for the 250/350 LC and also for the ypvs?? yes loads, I am certain I've posted various ones on here over the years, but you'll need to search for them, plus it depends if you want it for stock, tuned, slightly modifed or highly modified
Post by fletche36 on Jan 2, 2024 17:22:19 GMT 1
Do the mutts/alonze pipes fit well with a bellypan and centre stand ? just asking in case i decide to remove the swarbricks and go for something that drops the power down by 1k revs or so.
Post by beardy on Jan 2, 2024 18:42:21 GMT 1
Do the mutts/alonze pipes fit well with a bellypan and centre stand ? just asking in case i decide to remove the swarbricks and go for something that drops the power down by 1k revs or so. I have the mid range pipes and the centre stand fits with no issues 👍🏻
