Post by philbert on Dec 17, 2023 8:28:08 GMT 1
Hi folks anyone fitted 28mm keihin to 31k airbox? Did you manage to use the stock airbox rubbers or did you use an alternative?
Thanks
Post by midlifecrisisrd on Dec 17, 2023 9:49:19 GMT 1
Yes, stock rubbers
Fit them to the carbs first, then fut the carbs with the rubbers on
Post by philbert on Dec 17, 2023 10:02:25 GMT 1
Thanks Steve. Guess i need try harder lol
Post by jessy03 on Dec 17, 2023 11:03:02 GMT 1
Warm them up in some hot water first, makes it a bit easier to stretch them over. Jess
Post by abar121 on Dec 17, 2023 11:42:53 GMT 1
Also use good clamps on the carbs and leave the rubbers on when servicing the carbs at a later date, to avoid this agro again.
Some use a beer bottle to stretch the rubbers after hot water.
Post by 4l04ever on Dec 17, 2023 12:34:50 GMT 1
If you soak them in a solution of IPA and Wintergreen oil, they will go soft over a few days and actually grow in size. Just check them each day until they fit, then clamp them on and leave them to dry out. As they dry out they will return to their original size but will still be nice and supple. They will smell nice too.
Post by chrisg on Dec 17, 2023 14:32:24 GMT 1
I warm them in hot water, spray some gt85 silicone spray and use a lolly stick sanded to a soft edge, but still challenging.
Post by philbert on Dec 17, 2023 20:18:19 GMT 1
Thanks all. I got them on after boiling them till they softened.once the blisters on my fingers heal ill get them on the bike lol.
Post by philbert on Dec 17, 2023 20:24:51 GMT 1
Throttle cables to sort out next!
