Post by vectisitch on Nov 9, 2023 18:27:16 GMT 1
I'm going over my lc2 during it's winter check over changing oil seals ect. Found the water pump impeller shaft is knackered. It wasn't leaking but would soon. So I'm also changing the seal and bearing.Might be a stupid question but do I grease the new bearing?
Post by 4l04ever on Nov 9, 2023 18:28:43 GMT 1
The bearing will get lubricated by the gearbox oil. You can pre-oil it.
Post by vectisitch on Nov 9, 2023 18:29:54 GMT 1
Hmm. Should be a pic but I can't see it
Post by vectisitch on Nov 9, 2023 18:30:28 GMT 1
The bearing will get lubricated by the gearbox oil. You can pre-oil it. That's what I thought but best to check. Thanks
