peterb
Post by peterb on Nov 5, 2023 15:27:25 GMT 1
hi ive found that the main stand seems to be leaning forward what angle in degrees should it be ? and what should be the frame Hight be from the ground to the bottom frame rails? I've fitted new yss rear shock and new up rated fork springs hagon .side stand seem ok ?
Post by veg on Nov 5, 2023 15:30:20 GMT 1
The pivot holes wear elliptical and the stand leans forward meaning the rear tyre hits the floor. Normally down to people starting the bike in it’s stand check those holes first then check the stand isn’t bent.
Post by midlifecrisisrd on Nov 5, 2023 16:33:06 GMT 1
The main frame rail twists too
Post by JonW on Nov 6, 2023 5:27:41 GMT 1
yep, sitting on the bike eating your fish n chips as a teenage fatty happened to quite a few LCs it seems. :/
Post by spooch63 on Nov 16, 2023 22:14:17 GMT 1
I have the same main stand issue, is there a cure? Oversize pins?
Post by shaunthe2nd on Nov 16, 2023 23:31:27 GMT 1
I usually weld some 2-3mm thick spacers (coin shaped) onto the top of the stand.
Post by JonW on Nov 17, 2023 1:22:02 GMT 1
I do the same, something the size of a £1 Coin.
Post by sp885 on Nov 17, 2023 7:15:29 GMT 1
I had this problem with my LC when I first got it, the rear wheel was sitting on the ground when it was on the centre stand, one problem was the tubes that the stand brackets are fixed to, the weld on one side was cracked so I repaired that, then I drilled the holes out in the stand and the brackets as the holes were oval shaped and there was a bit of movement on the pin, so it could take a slightly larger pin, think it was 15 or 16mm from memory and made a new pin to suit it, however this only improved it slightly and got the rear wheel off the ground, but only a little bit, so I welded a couple of 3mm thick washers on top of the stand and that sorted it, still good about 8 years later, common LC problem
Post by chrisg on Nov 17, 2023 16:56:13 GMT 1
I do the same, something the size of a £1 Coin. Very decadent 😁
Post by JonW on Nov 17, 2023 23:24:32 GMT 1
I do the same, something the size of a £1 Coin. Very decadent 😁 With the cost of things today, washers are probably more exy than a real round pound! EDITED to add, before someone says something... dont try to weld an actual pound coin to anything, it's not the thing for the job. wrong metal.
Post by 4l04ever on Nov 18, 2023 10:10:04 GMT 1
Also....if you have fitted a YSS shock and extended the shock to raise the ride height then the back wheel may not be off the floor when on the centre stand.
peterb
Post by peterb on Dec 1, 2023 15:14:35 GMT 1
hi thanks for the info i have yet to investigate it further as having flu? but it sound like there is a solution and areas to look at
