Post by veg on Oct 13, 2023 17:20:32 GMT 1
That looks cracking 👍
Post by dusty350 on Oct 13, 2023 17:44:18 GMT 1
I agree, that looks great. 👍👍
Post by peter1962 on Oct 13, 2023 17:44:33 GMT 1
That looks really cool
Post by urbantangleweed on Oct 15, 2023 12:47:02 GMT 1
A few more photos of the finished piece. The only thing I'm unsure about is the textured surface at the top, which is transferred from the build plate. Colin Looks fab, how much for a 350 one black?
Post by reedx on Oct 15, 2023 14:50:33 GMT 1
[quote author=" urbantangleweed" Looks fab, how much for a 350 one black?[/quote] I've produced some test pieces in black already, but am still undecided whether it's something I'd be happy to take people's money for. I'm working through some physical issues of the material with Darren, and am probably on around my 20th test print. As an example we've worked out it needs printing at 100.25% of design size to allow for material shrinkage as it cools. The main issue currently is a slight problem with warping due to cooling on the bigger overhangs, leaving a small misalignment with the lower front edge of the crankcase. You can see it more clearly in the photos with the engineers square comparing one printed flat, which looks awful, and the vertical one. I'm trying a slightly different print orientation and some sacrificial internal supports to try and mitigate the issue. If I can solve the issues I was thinking of pricing them at £20 posted, assuming I can keep the print failure numbers low. Colin
Post by Gunny on Oct 15, 2023 17:44:44 GMT 1
Put my name down for one
Post by charles13 on Oct 15, 2023 17:54:01 GMT 1
Me too please
Post by urbantangleweed on Oct 15, 2023 20:33:08 GMT 1
If you get to the point you're happy enough with them to sell them Colin, I'll have one in black.
One other thing, the material you'll print them in, is it paintable?
Post by reedx on Oct 15, 2023 20:50:36 GMT 1
If you get to the point you're happy enough with them to sell them Colin, I'll have one in black. One other thing, the material you'll print them in, is it paintable? Yes they're sandable and paintable. Material is ASA, which is a UV stabilised version of ABS. Colin
Post by zig on Oct 15, 2023 21:18:32 GMT 1
excellent idea , they look amazing
ZiG
Post by tacky1 on Oct 16, 2023 1:44:42 GMT 1
Put me down for a 350 and a 421 cover.
Post by geoffb on Oct 16, 2023 4:08:01 GMT 1
Top job and a steal at £20 😎
Please put me down for one in Black with 350
Cheers
Geoff
Post by urbantangleweed on Oct 16, 2023 7:38:41 GMT 1
If you get to the point you're happy enough with them to sell them Colin, I'll have one in black. One other thing, the material you'll print them in, is it paintable? Yes they're sandable and paintable. Material is ASA, which is a UV stabilised version of ABS. Colin OK, well put me down for 2 x 350 in black, then if I mess one up trying to sand and paint it, I'll still have a good one!
jimmyg
Post by jimmyg on Oct 16, 2023 8:02:27 GMT 1
If you go ahead stick me down for one please Cheers Jimmy
Post by dougw on Oct 16, 2023 12:25:23 GMT 1
I'll have one too please , Black and blank or 350 if that's not possible ta.
simonh
Post by simonh on Oct 16, 2023 14:29:16 GMT 1
Nice job, I might have a crack at printing one in PETG, it's good for 85°C.
Post by reedx on Oct 17, 2023 12:37:34 GMT 1
Nice job, I might have a crack at printing one in PETG, it's good for 85°C. I'd be interested how you get on Simon. I'm having no luck solving what I believe is a warping issue. Colin
Post by jackjabba on Oct 19, 2023 7:24:30 GMT 1
Out of interest how did you model it. Did you scan an original and then modify?
Just about to invest in a new resin printer.
Post by reedx on Oct 19, 2023 12:34:03 GMT 1
Out of interest how did you model it. Did you scan an original and then modify? Just about to invest in a new resin printer. No, I bought the STL files from Cults3D. I do have a 3D scanner, but in this case I don't have the original cover on my bike as I run premix. I'm currently trying to reverse engineer the mesh in Fusion 360 to see if I can correct the issues. If it is cooling/warping causing the issues with the FDM print, then maybe a resin printer is the answer in this case? What resin printer are you looking to invest in? It's something I've never considered. What are the options like for higher temperate resistant resin print materials? Colin
Post by jackjabba on Oct 19, 2023 16:59:14 GMT 1
Out of interest how did you model it. Did you scan an original and then modify? Just about to invest in a new resin printer. No, I bought the STL files from Cults3D. I do have a 3D scanner, but in this case I don't have the original cover on my bike as I run premix. I'm currently trying to reverse engineer the mesh in Fusion 360 to see if I can correct the issues. If it is cooling/warping causing the issues with the FDM print, then maybe a resin printer is the answer in this case? What resin printer are you looking to invest in? It's something I've never considered. What are the options like for higher temperate resistant resin print materials? Colin Looking at an Elegoo Saturn 3 Ultra, or the Elegoo Mars 4 Ultra. The Saturn has a bigger build capacity, but the Mars has a better resolution with regard pixel size. Lots of reviewers say you cant really see the difference in the prints, so will probably just go for the Saturn, as you never know when you may need the extra size. Mainly will be using it for parts for model kits. First thing after calibration will be to print the parts for an Apollo lunar lander in 1/24 scale. For high temperature you could use Phrozen Ultra High Temp resin, heat deflection up to 190C. Its not cheap resin at £60 a bottle, but they do 120C resin for half the price.
Post by reedx on Oct 19, 2023 17:18:53 GMT 1
No, I bought the STL files from Cults3D. I do have a 3D scanner, but in this case I don't have the original cover on my bike as I run premix. I'm currently trying to reverse engineer the mesh in Fusion 360 to see if I can correct the issues. If it is cooling/warping causing the issues with the FDM print, then maybe a resin printer is the answer in this case? What resin printer are you looking to invest in? It's something I've never considered. What are the options like for higher temperate resistant resin print materials? Colin Looking at an Elegoo Saturn 3 Ultra, or the Elegoo Mars 4 Ultra. The Saturn has a bigger build capacity, but the Mars has a better resolution with regard pixel size. Lots of reviewers say you cant really see the difference in the prints, so will probably just go for the Saturn, as you never know when you may need the extra size. Mainly will be using it for parts for model kits. First thing after calibration will be to print the parts for an Apollo lunar lander in 1/24 scale. For high temperature you could use Phrozen Ultra High Temp resin, heat deflection up to 190C. Its not cheap resin at £60 a bottle, but they do 120C resin for half the price. Just had a look at both of those models and they're a lot cheaper than I was expecting. For some reason I thought resin machines would be more expensive than FDM? Or is it the consumables that are expensive? Do you already have a resin printer and are upgrading? Colin
Post by jackjabba on Oct 19, 2023 18:42:40 GMT 1
Sold my last resin printer a couple of years ago, so this next one will be a lot better than the old one I use to have.
Consumables add up compared to FDM. Good quality resin can cost quite a bit and then you need to buy IPA to wash with. You can get water washable resins, some hate them others love them. Once washed you then need to UV cure the resin. so on top of the printer you may need to buy a wash and cure setup, £100 - £180 depending on size. Last time I bought a bucket and fitted UV led strip inside it for curing, and had a small battery turntable to sit the print on. I will probably buy the Elegoo max wash and cure station this time around.
Post by ukcalling on Oct 29, 2023 9:20:13 GMT 1
I'm in if you make them please - black 350
Thanks Nick
Post by daveyl on Nov 22, 2023 10:32:36 GMT 1
Put me down for 2 please in black 250 and 350 versions.
Post by luistf76 on Nov 22, 2023 11:31:43 GMT 1
nice... its that ASA paintable?
Post by reedx on Nov 22, 2023 12:48:29 GMT 1
About time I updated everyone on this one. After many attempted fixes I never managed to completely eliminate an issue with the print. As you can see from the images below there is still a small alignment issue with the front lower edge of the cover. I've taken a close up shot with a straight edge on the engine case to highlight it. It's probably only really going to be noticed if the bike is up on a lift or you've just been run over by it I've ummed and ahhed over whether to offer these to forum members, but if you're still happy to take them then then I'll print them. Bottom photo is of a couple I've done for Darren. Colin
Post by jessy03 on Nov 22, 2023 15:37:49 GMT 1
I think they look great, not a perfect fit but once painted you don’t notice it. Thanks again Colin, top man 👍
jimmyg
Post by jimmyg on Nov 22, 2023 15:40:22 GMT 1
Looks ok to me, can I take a 350 one please Cheers Jimmy
Post by tacky1 on Nov 22, 2023 18:32:07 GMT 1
Looks great. I’ll take a 421 cover please.
Post by urbantangleweed on Nov 22, 2023 21:08:23 GMT 1
I'll take 2 x 350s please Colin.
