Post by 4l04ever on Nov 10, 2024 19:33:53 GMT 1
Fitted new front sprocket with new lock washer and replated nut.
Post by 4l04ever on Nov 10, 2024 19:35:45 GMT 1
My chain was too long, so I borrowed my friend's chain tool. It was super easy to split the chain. I then fitted the new chain and aligned it with my Laser Alignment Tool.
Post by 4l04ever on Nov 10, 2024 19:37:53 GMT 1
I also fitted the rear brake arm and brake rod, so the rear brake is now working.
Post by 4l04ever on Nov 10, 2024 19:39:51 GMT 1
I started getting the clutch actuator mechanism fitted in the left cover as the rain started, so I had to put everything away.
Post by JonW on Nov 11, 2024 2:08:59 GMT 1
Love that brake disc Rob, Im sure Ive asked you before but Im getting on a bit (er?!)... Can I ask again, 'whats that off?'
Post by 4l04ever on Nov 11, 2024 17:24:53 GMT 1
Love that brake disc Rob, Im sure Ive asked you before but Im getting on a bit (er?!)... Can I ask again, 'whats that off?' It is a 320mm disc off a TZR250 2MA / TDR250. That is for mockup. I managed to get a new EBC disc with a gold centre for £80.
Post by JonW on Nov 11, 2024 23:32:34 GMT 1
Ohh nice, Cheers Rob.
Post by 4l04ever on Nov 12, 2024 17:47:57 GMT 1
The front disc has a spacer behind it. Made by NK Racing.
Post by 4l04ever on Nov 25, 2024 22:57:01 GMT 1
The wheel was removed to get a new BT46 tyre and inner tube fitted. Before putting it back in, the new disc will also be fitted.
I put the oil in the engine too. 2 litres is what I use for now.
I also built up the left engine casing and fitted it, then adjusted the clutch. The clutch is nice and light.
Post by tout on Nov 28, 2024 23:10:42 GMT 1
Keep the piccys coming Rob, top work and dedication
Post by 4l04ever on Dec 1, 2024 16:28:44 GMT 1
Left side cover pic.
Post by 4l04ever on Dec 1, 2024 16:30:03 GMT 1
New disc fitted with new tyre. Now back in the bike. I need to finalise disc bolts.
Post by 4l04ever on Dec 1, 2024 16:31:03 GMT 1
Found a NOS front caliper in the stash for this project.
Post by 4l04ever on Dec 1, 2024 16:35:33 GMT 1
Or this one....
Post by 4l04ever on Dec 1, 2024 21:40:22 GMT 1
Caliper fitted, brake line fitted, bled up
Post by JonW on Dec 1, 2024 23:29:25 GMT 1
Looks great Rob. Ive been searching all over for a disc spacer and cant find one. Do you have any advice on this? Or dimensions to get one made? I had hoped that most Yams of the era had the same PCD to the bolt pattern so there was a generic spacer in various widths available, but all Ive found ready made is an SR spacer at Motolana and it doesnt list all the dims, but does look like 2 sets of holes and says '80mm bolt pattern', but thats only part of the sizing for this as the lip is important of course: www.motolanna.com/ourshop/prod_3022255-Brake-Rotor-Spacer-10mm-Yamaha-SR500-SR400.htmlAnyway, interested in what you have to say on this Rob, Id love to do the same setup.
Post by 4l04ever on Dec 1, 2024 23:35:40 GMT 1
I got the spacer and the caliper bracket from NK Racing.
Post by midlifecrisisrd on Dec 1, 2024 23:59:53 GMT 1
Looks great Rob. Ive been searching all over for a disc spacer and cant find one. Do you have any advice on this? Or dimensions to get one made? I had hoped that most Yams of the era had the same PCD to the bolt pattern so there was a generic spacer in various widths available, but all Ive found ready made is an SR spacer at Motolana and it doesnt list all the dims, but does look like 2 sets of holes and says '80mm bolt pattern', but thats only part of the sizing for this as the lip is important of course: www.motolanna.com/ourshop/prod_3022255-Brake-Rotor-Spacer-10mm-Yamaha-SR500-SR400.htmlAnyway, interested in what you have to say on this Rob, Id love to do the same setup. Aprillia has the same dimension Plenty of spacers for them Steve
Post by 4l04ever on Dec 2, 2024 0:16:35 GMT 1
NK Racing spacers match the shape of the LC wheel.
Post by JonW on Dec 2, 2024 0:41:20 GMT 1
Super info, thanks all!
