Post by 4l04ever on Jul 14, 2024 22:00:54 GMT 1
Post by 4l04ever on Jul 14, 2024 22:01:44 GMT 1
Built up rear brake ready for fitting. ![](https://uploads.tapatalk-cdn.com/20240714/6816e0e47054d0fdd7193ba2f6bd4248.jpg) ![](https://uploads.tapatalk-cdn.com/20240714/6086bd53479f08c8bcd97886675ce374.jpg)
Post by 4l04ever on Jul 17, 2024 21:25:50 GMT 1
I fitted the front wheel in.
I am just waiting on a few more black parts, then I can fit the rear wheel.
Post by 4l04ever on Jul 20, 2024 0:13:22 GMT 1
My mate popped round this morning and helped get the rear wheel in. ![](https://uploads.tapatalk-cdn.com/20240719/42c0783ecdedf0b6a480ca5622ffac9c.jpg)
Post by 4l04ever on Jul 20, 2024 0:14:36 GMT 1
Fitted rear subframe. ![](https://uploads.tapatalk-cdn.com/20240719/1e0c53153bb8cc7cd9e98c61c23e9bb9.jpg)
Post by 4l04ever on Jul 20, 2024 0:15:30 GMT 1
Changed yoke nut to a black one. ![](https://uploads.tapatalk-cdn.com/20240719/6bfe0cfb01928658a174a9f89ab54ff0.jpg)
Post by 4l04ever on Jul 20, 2024 0:23:53 GMT 1
Post by 4l04ever on Jul 20, 2024 14:20:12 GMT 1
Fitted rear mudguard and number plate holder. ![](https://uploads.tapatalk-cdn.com/20240720/7941abaa720d6ca18ac8717ac7efa51c.jpg)
Post by 4l04ever on Jul 22, 2024 19:25:32 GMT 1
Cleaned up battery tray and rectifier. Fitted on and bolted on fusebox. ![](https://uploads.tapatalk-cdn.com/20240722/56d4bec710fb8a628800508976a66026.jpg)
Post by 4l04ever on Jul 22, 2024 19:28:42 GMT 1
Rewired pattern indicators, so they have correct colour and length cables. Also rewired a pattern tail light. All now fitted on. Just need to trim wires to correct lengths and put connectors on. ![](https://uploads.tapatalk-cdn.com/20240722/8096829adba125b295690bc0086812f3.jpg) ![](https://uploads.tapatalk-cdn.com/20240722/a7d385728903dcf93c4390bad8b10df3.jpg) ![](https://uploads.tapatalk-cdn.com/20240722/ee13ba9e2fda12d901fb01ed54c08780.jpg) ![](https://uploads.tapatalk-cdn.com/20240722/f27f9e15c1a4bcdd393b81c00b622bf7.jpg)
Post by 4l04ever on Jul 22, 2024 19:30:06 GMT 1
So far... ![](https://uploads.tapatalk-cdn.com/20240722/f0f1eca95a47a468d139d9df26680425.jpg)
Post by 4l04ever on Jul 22, 2024 19:58:34 GMT 1
Found a pair of Raask rearsets Yes or no? ![](https://uploads.tapatalk-cdn.com/20240722/51d7c9b211b563143c613b35760007e5.jpg) ![](https://uploads.tapatalk-cdn.com/20240722/59857387e93acd45aa677f9f2dc17356.jpg)
Post by abar121 on Jul 22, 2024 20:19:16 GMT 1
Yes
Post by 4l04ever on Jul 22, 2024 21:53:14 GMT 1
Popped the tank and side panel on. ![](https://uploads.tapatalk-cdn.com/20240722/7a6fe8f01ce6d83a0d806cf37fc9a450.jpg) ![](https://uploads.tapatalk-cdn.com/20240722/a919577a923b00a3125a319a3049bf0a.jpg)
Post by archloafer on Jul 22, 2024 23:00:54 GMT 1
Found a pair of Raask rearsets Yes or no? ![???](//storage.proboards.com/forum/images/smiley/huh.png) . Yeah. I remember seeing these advertised in the back of PB in the 90s, but never seen them properly until now. Maybe get some clock protector ace bars to go with? ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
Post by 4l04ever on Jul 27, 2024 8:24:13 GMT 1
Post by 4l04ever on Jul 28, 2024 23:19:03 GMT 1
Post by 4l04ever on Jul 30, 2024 21:48:25 GMT 1
Bottom end of engine fitted. ![](https://uploads.tapatalk-cdn.com/20240730/d1e502bc8d5ec61193d960e110f8dbe5.jpg)
Post by tout on Aug 1, 2024 22:46:15 GMT 1
good work Rob 👌
Post by pdxjim on Aug 2, 2024 7:53:16 GMT 1
Found a pair of Raask rearsets Yes or no? Made from recycled Oranjeboom cans and fragile as a Crunchie bar. In the '90's, they were about all we could get new over here for our aircooled RDs. Be mindful of the kickstart clearance. I knew how to short stroke (!) it when kicking mine over, but every time I let someone else have a go, it came back with a broken brake pedal. I bought replacements two at once after a while.
Post by 4l04ever on Aug 5, 2024 16:40:45 GMT 1
Just waiting for new pistons for the 370 kit.
I found another pair of 350 cylinders. I vapour blasted them, then taking them for a rebore later this week.
Post by 4l04ever on Aug 9, 2024 15:25:29 GMT 1
Managed to find a good clutch basket with 68 gear to match my 88 crank primary gear. Fitted on with new EBC DRC clutch plates. Fitted OEM springs. ![](https://uploads.tapatalk-cdn.com/20240809/1a8f231355bdc92d1f1a0bceba463d1e.jpg)
Post by 4l04ever on Aug 9, 2024 16:09:56 GMT 1
Fitted rear brake light switch. Had to shorten the spring to make it work. ![](https://uploads.tapatalk-cdn.com/20240809/985d735011b3272f7fb5e3e8e06cdbba.jpg)
Post by peter1962 on Aug 9, 2024 17:36:22 GMT 1
Coming along nicely, Rob
Post by 4l04ever on Aug 9, 2024 20:41:13 GMT 1
Fitted front mudguard. Fitted led bulb in headlight and fitted glass. ![](https://uploads.tapatalk-cdn.com/20240809/7990344391dd5eae64e6fb45fb9cd9c3.jpg) ![](https://uploads.tapatalk-cdn.com/20240809/7ccf901d6fe2c4694ae9306d2e45c074.jpg) ![](https://uploads.tapatalk-cdn.com/20240809/a95bc9d2cc84749a5c2824e903fd4d7b.jpg)
Post by 4l04ever on Aug 14, 2024 21:47:34 GMT 1
Cylinders away for powder coating. Found this in my stash, so fitted it for now. ![](https://uploads.tapatalk-cdn.com/20240814/fe41702bdcb43bb03914523bbfa4f023.jpg)
Post by JonW on Aug 23, 2024 0:18:48 GMT 1
coming along nicely, loving the Raasks! (but then i would!)
Post by 4l04ever on Aug 23, 2024 7:47:08 GMT 1
coming along nicely, loving the Raasks! (but then i would!) I will probably give them a try to see if they are ok for day-to-day use. If not, I will go back to standard.
Post by JonW on Aug 23, 2024 8:00:42 GMT 1
coming along nicely, loving the Raasks! (but then i would!) I will probably give them a try to see if they are ok for day-to-day use. If not, I will go back to standard. I reckon at our age they wont be ideal. I have mine on my 421 with MX bars and they are a bit hard work, but i like the look so they stay on...
Post by Tobyjugs on Aug 25, 2024 11:57:21 GMT 1
A few years ago I was struggling with the Tarrozzi set up. I put them on the track RD and thought hmm not so good, bit to my surprise they were OK. I think this was because I lost a few kilos.
