Post by spondon440 on Jul 9, 2023 19:01:23 GMT 1
Can anyone advise what the ignition timing should be set at on a 31k motor using a vape ignition system run through ignitec, I'm reading 1.8mm to 2.0mm btdc, is this correct?
Andy
Post by muttsnuts on Jul 9, 2023 19:09:50 GMT 1
2mm BTDC, which equates to 21 deg BTDC (assuming its a stock crank/stroke etc)
Post by spondon440 on Jul 9, 2023 20:55:47 GMT 1
It is, thanks Dave. Regards Andy
