Post by spacejunkie on Jul 7, 2023 18:05:33 GMT 1
Hello everyone
Has anyone had any problems with the bleed screws leaking… calipers are gsxr400 calipers on a hybrid I am building and the bloody bleed screws are leaking.
On all the bikes I have messed around with I have never had this problem before
Anyone got any ideas ?
Thanks in advance
Post by chrisg on Jul 7, 2023 19:28:44 GMT 1
I have read some pattern screws not sealing correctly. Is it OE or pattern?
Post by spacejunkie on Jul 7, 2023 19:34:07 GMT 1
Genuine suzuki ones.
Bloody expensive as well
Post by chrisg on Jul 9, 2023 14:41:21 GMT 1
Can you see the area where the screw seals? Is it rough? Not sure if the seat can be re-cut.
Post by muttsnuts on Jul 9, 2023 14:47:36 GMT 1
could be the wrong taper on the bleed screw, had that before, and also the wrong thread, both will cause thme to leak
Post by siabost78 on Jul 15, 2023 14:22:10 GMT 1
I had the same issue on my front gsxr400 caliper. The seat was damaged so it wouldn't seal. They were rough anyway so i sent them to powerhouse for a refurb. They welded the hole, pressure tested and supplied the banjo bolt with a bleed nipple in it.
Post by chrisg on Jul 15, 2023 14:50:29 GMT 1
I had the same issue on my front gsxr400 caliper. The seat was damaged so it wouldn't seal. They were rough anyway so i sent them to powerhouse for a refurb. They welded the hole, pressure tested and supplied the banjo bolt with a bleed nipple in it. Simple solutions are sometimes the best.😉
