Post by darboots on Jun 5, 2023 10:00:28 GMT 1
Has anyone fitted a Dyna coil to an LC2? If so, are you able to share how best to do this, please?
I originally had replaced the standard (40 year old) coil with a pair of Banshee (type) coils. However, I've replaced these with a single Dyna coil. But, I can't seem to decide on how best to mount the Dyna coil where the original fits. There doesn't seem to be a happy medium for the low tension and high tension leads to fit correctly. I have the standard 'electronics' tray, with the reg/rec on the underside, the flasher self cancel unit towards the headstock, a PC10VT in place of the standard CDI, and the flasher relay in it's usual place.If I use the upper threaded mount, the rear fouls on the plastic electronics tray. Should I knock up some 90 degree brackets and mount it with the HT leads downwards? Any pointers gratefully received....
Post by sidney81 on Jun 5, 2023 10:08:59 GMT 1
I did ! I made up X2 10 mm thick spacers to space it off the frame and it sits perfectly 👍
Post by darboots on Jun 5, 2023 11:18:28 GMT 1
I did ! I made up X2 10 mm thick spacers to space it off the frame and it sits perfectly 👍 Is that on top of the frame? i.e. frame --> spacer --> coil mount --> washer --> bolt?
Did you need to cut the plastic reg/rec tray?
Would be interested in a picture if you're able.
Post by sidney81 on Jun 5, 2023 12:01:41 GMT 1
yes like that,no didn't cut it see if I have a picture
Post by sidney81 on Jun 5, 2023 12:06:05 GMT 1
Not the best picture but you can see how it's mounted,it's sitting on the 10 mm spacer's 👍
Post by darboots on Jun 5, 2023 12:31:52 GMT 1
Not the best picture but you can see how it's mounted,it's sitting on the 10 mm spacer's 👍 Brilliant. Thanks for doing that. I'll have a go at replicating your setup.
Dar.,
Post by sidney81 on Jun 5, 2023 12:48:38 GMT 1
Your welcome 🤗
Post by JonW on Jun 5, 2023 13:55:40 GMT 1
FYI Economy Cycle sells a mounting kit for this.
Post by darboots on Jun 5, 2023 15:10:43 GMT 1
FYI Economy Cycle sells a mounting kit for this. Thanks Jon. That's very interesting too. Hadn't thought of raising the Reg/Rec tray!
Post by darboots on Jun 5, 2023 15:15:18 GMT 1
FYI Economy Cycle sells a mounting kit for this. Thanks Jon. That's very interesting too. Hadn't thought of raising the Reg/Rec tray! Well, that killed a sale...
Subtotal $35.00 Shipping International Delivery: $49.95 Shipping to BRISTOL, UK
Should be able to make my own 'kit' up using that list/picture.
Post by darboots on Jun 14, 2023 16:45:00 GMT 1
So, just to close this off. I've bought: 2 x 9.5mm stainless spacers 2 x 19mm stainless spacers A new 2 way 6.3mm connector (from Kojacat) The Economy Cycle kit only has a spacer under one (rearmost) end of the coil, which I tried, but was concerned about the extra strain on the coil mounts, so I bought a second 9.5mm spacer for the front end. New bolts to suit. All in, I think it's cost me about £18.
Post by sidney81 on Jun 14, 2023 22:34:02 GMT 1
Looks good 😊👍
