Post by alext900 on May 11, 2023 20:43:59 GMT 1
Ok finally got round to fitting fuel hoses on the hybrid project, hmmm Old carbs would have balance pipe supplying both carbs, these are basically 2 carbs with individual chokes etc, so how have you guys got these pipes up? Fuel at on with t piece to both carbs is where I’m starting then from reserve with another t piece, seems a bit messy but is this the only way!
Post by alext900 on May 11, 2023 20:44:51 GMT 1
Ps forgot to say they are 28mm flat slides from this site!
Post by midlifecrisisrd on May 11, 2023 21:20:08 GMT 1
If its an LC then the 2 spigots on the tap feed on both on and res so just 1 pipe from each spigot to each carb
Post by rigga on May 11, 2023 21:26:00 GMT 1
As Steve says, the spigots from the tap are the same , it's the tap that changes flow from on to reserve. So one pipe from one spigot to one carb, and the other to the other carb.
I have a single spigot tap, so need a T piece, you don't.
The balance pipe was for choke operation, as standard lc carbs only had the choke on one carb, the 28 flatslides have a choke each.
