Post by jimblob on May 3, 2023 15:56:24 GMT 1
Hi guys,
I’ve just joined the crankcases on my YPVS rd350r. Everything all torqued up correctly and I was just congratulating myself on a job well done when I realised I’ve put the washer on the clutch actuating arm above the spring rather than below it (against the seal)!!!!!
Bit of a newb question but should I undo all the torqued crankcase bolts to move the washer or will that cause the crankcases to seperate and damage the seal on the mating surfaces…….Or can i just undo the one bolt that retains the arm. …….Or shall I just leave well alone.
Any advice gratefully received.
Cheers
Jim
Post by Yogi on May 3, 2023 16:04:04 GMT 1
Just undo the one bolt mate The main part that needs to be sealed is the crank which is bolted on the bottom nuts Matt 🐻
Post by jimblob on May 3, 2023 16:09:07 GMT 1
Cheers Matt. I was well panicking. First rebuild and all that!!!!
I’ll undo the one bolt real quick with my eyes shut 😀
Cheers
Jim
Post by Yogi on May 3, 2023 16:55:02 GMT 1
Cheers Matt. I was well panicking. First rebuild and all that!!!! I’ll undo the one bolt real quick with my eyes shut 😀 Cheers Jim Lol 😂
Post by billbott on May 3, 2023 17:04:27 GMT 1
Cheers Matt. I was well panicking. First rebuild and all that!!!! I’ll undo the one bolt real quick with my eyes shut 😀 Cheers Jim Lol 😂 Made me LOL too 😂😂
Post by Tobyjugs on May 3, 2023 17:21:11 GMT 1
Just make sure you use the torque wrench to tighten it up. This sort of thing happens all the time. The club has a huge membership!
Post by jimblob on May 3, 2023 19:47:09 GMT 1
Cheers for the advice guys.
Think I’m gonna be a member of a few more clubs by the time this ****** bike is finished!!!!
Jim
Post by JonW on May 4, 2023 1:52:10 GMT 1
Defo not a problem to redo this one bolt, I once swapped all the case bolts and nuts one at a time to freshen them up like this with no problems.
