Post by jimblob on May 1, 2023 17:27:00 GMT 1
Hi Guys,
I am finally ready to bolt the crank cases together on my rd350r (1995).
Ive got the Haynes manual but it gives x2 very different torque settings in the main text (LC2, N and F models) compared to the text in chapter 8 for the F2, N2 and R models.
In the main text it states Upper crankcase bolts = 7.2 ft/lbs Lower crankcase bolts = 18 ft/lbs
In Chapter 8 it states Upper crankcase bolts = 7.2 ft/lbs Lower crankcase bolts = 5.7 ft/lbs !!!
I’ve tried searching everywhere but can’t find the values for the rd350r. I presume Mr Haynes is wrong (again) and the 7.2 ft/lbs uppers and 18 ft/lbs lowers are the correct values for all models.
Cheers
Jim
Post by chrisg on May 1, 2023 22:19:07 GMT 1
Just a thought, is the head to be torqued up in 2 stages?
I usually do it in several stages.
Post by jimblob on May 2, 2023 11:46:54 GMT 1
Thanks for the response Chrisg. In the main text it does give lower figures initially to gradually torque it up to the final figure but chapter 8 only gives the x2 figures above. I presume I’m safe to just go with 18ft/lb bottom nuts and 7ft/lb top nuts?
Cheers
Jim
Post by midlifecrisisrd on May 2, 2023 11:54:10 GMT 1
The higher figure sounds right
The lower sounds ridiculous
Almost like they have listed the first stage torque rather than the final
Post by jimblob on May 2, 2023 12:32:12 GMT 1
Thanks Steve.
It was listed at the bottom of the page so I turned the page over expecting to see the rest of the figures but that was all there was!!! 😬
Mr Haynes strikes again 😳
Jim
