Post by elsiefan on Apr 29, 2023 1:15:16 GMT 1
Can anyone advise if the rubber 'O' ring in the picture goes in to the recess on the top of the cases, then the cable guide feeds through it? or feed the cable guide through the cases and fit the 'O' ring to the guide from underneath? There wasn't one fitted when I stripped the bike down, so I am unsure which way to fit it. Oil pump
Post by JonW on Apr 29, 2023 1:48:01 GMT 1
Ive always fitted it to the case, so its on the outside. It would seal the hole from water ingress. I see no benefit for it being inside.
Post by dusty350 on Apr 29, 2023 9:23:10 GMT 1
O ring is outside the case
Post by elsiefan on Apr 29, 2023 10:06:20 GMT 1
Thanks guys 👍 I also thought it made the most sense fitting it to the recess on the outside of the cases. But I like to check with the experts.
Post by midlifecrisisrd on Apr 29, 2023 11:05:39 GMT 1
Not so much fitted in the recess but slid up the cable end against the flange
Ends up in the same place
Post by JonW on Apr 29, 2023 13:51:20 GMT 1
pmsl, yes its a terrible fit and defo an afterthought i fear.
Post by elsiefan on Apr 29, 2023 23:36:12 GMT 1
Not so much fitted in the recess but slid up the cable end against the flange Ends up in the same place Steve That was how I ended up fitting it, nothing like pressing up against a flange 😂
Post by elsiefan on Apr 29, 2023 23:38:36 GMT 1
I also checked the oil pump settings after, and the 'O' ring had changed the settings, lifting the cable guide up a little further meant there was a bit more tension on the cable and it was over oiling. Still better too much lube than not enough fnarr fnarr
