mungo
Post by mungo on Apr 1, 2023 14:45:35 GMT 1
Oil light was recently flickering and now is on permanently bottle is full is the sensor knackered or could it be something else
Post by Chewie01 on Apr 1, 2023 14:51:47 GMT 1
It could be a bad connection somewhere. Probably best to get a meter on the sensor connections and see if it changes when you put the sensor in and out of the oil tank.
mungo
Post by mungo on Apr 2, 2023 21:48:49 GMT 1
Should the oil light stay on when bike is in neutral ticking over and then go out when moving
Post by 4l04ever on Apr 2, 2023 22:05:49 GMT 1
Should the oil light stay on when bike is in neutral ticking over and then go out when moving Yes, unless the tank is empty.
mungo
Post by mungo on Apr 2, 2023 22:09:22 GMT 1
Thanks 👍
Post by rigga on Apr 2, 2023 22:20:37 GMT 1
Could be the sensor, or the wire down to earth somewhere, which completes the circuit for the oil light, it's earthed when in neutral,so the light illuminates as a test, select gear and the earth is lost, so light goes out.
