tbones
Post by tbones on Mar 30, 2023 21:00:32 GMT 1
I’m thinking of purchasing one. For working on Rd 350lc how good are they and what size adapters would need to purchase many thanks
Post by rigga on Mar 30, 2023 21:13:33 GMT 1
ABBA stands are a great bit of kit, use one all the time on my KTM, don't have the adaptors for the LC, but apparently you need a 19mm and a 22mm pair .
My swing arm spindle is not the original, so need to do a bit of research to find the right kit for mine.
Post by stusco on Mar 30, 2023 21:14:13 GMT 1
Ive got the hydraulic superbike lift its great I’ve built a lc a lc2 and a gamma sofar with no problems can’t remember what adapter ive got I would need to go and look but the will supply any size you need just give them the size you want
Post by midlifecrisisrd on Mar 30, 2023 21:24:11 GMT 1
I've got a stand and the roller kit
Can't remember the sizes, sorry
Love being able to wheel it out the way when I need space
Wouldn't be without it now. I also bought the swing arm removal bobbin kit. You can bolt them into the footrest bolts so you can remove the spindle and back end
tbones
Post by tbones on Mar 30, 2023 22:17:52 GMT 1
That’s a great help every one. I did I ask them today about the adapters and unfortunately the person didn’t know Thanks Dan
Post by rigga on Mar 31, 2023 8:28:54 GMT 1
LC adaptor kits are advertised on eBay for £26, lots of them, think it's a generic pic but from sellers like demon tweeks
Post by midlifecrisisrd on Mar 31, 2023 8:33:14 GMT 1
I can't remember needing an LC kit
Does the cups it comes with not do an LC?
Stusco gave me the ypvs ones, I remember that 👏
Post by abar121 on Mar 31, 2023 11:06:50 GMT 1
Great stands, as above. I have a few sets of adapters, it can get expensive.
If someone could knock up some Abba stand adapters to 1/2" socket, that would save a lot of faffing around. It'd need to be greased up to allow it to spin.
Post by Robbieben on Mar 31, 2023 11:45:27 GMT 1
I have an Abba Sky lift and the full mechanics adapter set, great piece of kit, I havent found a bike I cant lift yet.
Post by midlifecrisisrd on Mar 31, 2023 12:25:29 GMT 1
Great stands, as above. I have a few sets of adapters, it can get expensive. If someone could knock up some Abba stand adapters to 1/2" socket, that would save a lot of faffing around. It'd need to be greased up to allow it to spin. Now that's an idea 😁 Think I'll buy a couple of 3/8 female to 1/2 adaptors then fab up cups on the lathe then weld together Or then again could just make a set of adaptors going up in size Although using sockets would stop the adaptors spinning on the spindle and marking the plating Steve
Post by abar121 on Mar 31, 2023 12:50:55 GMT 1
Great stands, as above. I have a few sets of adapters, it can get expensive. If someone could knock up some Abba stand adapters to 1/2" socket, that would save a lot of faffing around. It'd need to be greased up to allow it to spin. Now that's an idea 😁 Think I'll buy a couple of 3/8 female to 1/2 adaptors then fab up cups on the lathe then weld together Or then again could just make a set of adaptors going up in size Although using sockets would stop the adaptors spinning on the spindle and marking the plating Steve I'd be happy to contribute to any biscuit / coffee fund!
Post by Tobyjugs on Mar 31, 2023 14:10:19 GMT 1
I really like the stand because you can do maintenance work on the bike without having to take pipes off for extra support.
crigar
Post by crigar on Apr 4, 2023 17:35:23 GMT 1
For a small bike like the RDLC, why not use a small table like the one used in the circuit paddock ?
Post by abar121 on Apr 4, 2023 17:59:28 GMT 1
The next best thing to a centre stand.
Post by bernardo on Apr 5, 2023 9:15:28 GMT 1
Great bit of kit, but ABBA told me they'd make LC fittings to order since the spindles varied so much (bleed nipples etc). No extra cost and very nice to deal with
tbones
Post by tbones on Apr 5, 2023 18:36:37 GMT 1
Great bit of kit, but ABBA told me they'd make LC fittings to order since the spindles varied so much (bleed nipples etc). No extra cost and very nice to deal with I’ve just revived mine ( stand not lift from Demond tweeks and a 350lc fitting kit from them also. the fitting kit does not fit as advertised on eBay. I will contact them tomorrow to find out what’s gone wrong
tbones
Post by tbones on Apr 5, 2023 19:12:13 GMT 1
Has any one had problems using the stand..... mine seems to touch the foot brake peddle. Or has any one a picture or two with a 350lc on it . Many ThanksDan
Post by midlifecrisisrd on Apr 5, 2023 19:55:13 GMT 1
I know it's a ypvs but I've had to turn it around on some bikes Steve
tbones
Post by tbones on Apr 5, 2023 20:22:46 GMT 1
tbones
Post by tbones on Apr 5, 2023 20:26:44 GMT 1
Thanks for the picture I’ve had another go with a more relaxed frame of mind. Many ThanksDan The problem is mainly I’ve been sent the wrong adapters.
stoney
Post by stoney on Apr 5, 2023 21:33:45 GMT 1
Abba skylift works fine for me. I haven't got the space to have a dedicated bike bench.
