Post by KevtheRev on Mar 9, 2023 13:59:53 GMT 1
Is it possible to have the drum liner replaced on the standard LC rear wheel ?? I just found a hairline crack in mine while fitting new brake shoes
Post by 4l04ever on Mar 9, 2023 18:51:15 GMT 1
It is theoretically possible, but probably cheaper and quicker to get another wheel.
Post by steeley on Mar 9, 2023 20:22:19 GMT 1
There was a chap who advertised in one of the bike mags about replacing a drum liner in a wheel .Its been a long time but it would either be CMM or Practical Sports bikes.
Post by veg on Mar 9, 2023 21:08:07 GMT 1
Had exactly the same a few years ago can’t remember the exact cost but as Rob says it was definitely cheaper to get an undamaged wheel.
Post by Norbo on Mar 9, 2023 22:12:52 GMT 1
Its allways the 350 ones that do this far less on the 250lc dont know why . Ive never come accross any o ne that does this but i bet some one out there must
Post by KevtheRev on Mar 10, 2023 6:38:16 GMT 1
Thanks lads . I'm wondering how easy it is to find a decent second hand 40yr old wheel and what it might cost . I'd imagine they're pretty thin on the ground . Has anyone got this bloke's phone number ??
Post by headcoats on Mar 10, 2023 10:24:58 GMT 1
Better put your wheel in a suitcase and book a flight to Islamabad !
Post by cb250g5 on Mar 10, 2023 10:33:23 GMT 1
Apart from filling the bearing full of swarf, I reckon that's not a bad job of prolonging the life of a worn out wheel.
Post by KevtheRev on Mar 10, 2023 11:58:34 GMT 1
Better put your wheel in a suitcase and book a flight to Islamabad ! Probably work out cheaper than getting it done here too , lol .
Post by KevtheRev on Mar 10, 2023 12:00:40 GMT 1
Apart from filling the bearing full of swarf, I reckon that's not a bad job of prolonging the life of a worn out wheel. Seemingly it was a common enough procedure back in the day ,
Post by headcoats on Mar 10, 2023 12:06:24 GMT 1
Seems mad that no one in this country offers the service
Post by midlifecrisisrd on Mar 10, 2023 13:19:04 GMT 1
Chapped in with a hammer and a metal block
Am I the only one thinking it should have been such a tight fit that it should need a press?
And never mind the swarf in the bearing, what about leaving the cush rubbers in while heating it 😬
Post by alankelly on Mar 10, 2023 16:22:55 GMT 1
I had the rear drum liner crack on my old CB400F (Spoke type wheel) It can be replaced but it also allot of hard work so I can fully understand why it’s so expensive. As you first need to bore out the old cracked liner (that was cast in originally) then you had to find a car drum brake that was about the right dimensions so you could machine up a one off liner that then was a shrink fit into your bored out hub And then after fitting you still needed to pin the liner to the hub it to stop it possible rotating in the wheel hub under heavy braking, as like I said originally the wheel hub was cast around the liner so very secure. So for me it was easier to just modify the original drum brake hub to accept to a disc brake set up Lastly just for info on the Honda forum a guy called Paul Jackson (an engineer based in Huddersfield) has replaced some cracked liners on old Hondas but not sure if he is still about but maybe worth a Google using his name and location? Best wishes Al
Post by KevtheRev on Mar 10, 2023 18:47:35 GMT 1
I had the rear drum liner crack on my old CB400F (Spoke type wheel) It can be replaced but it also allot of hard work so I can fully understand why it’s so expensive. As you first need to bore out the old cracked liner (that was cast in originally) then you had to find a car drum brake that was about the right dimensions so you could machine up a one off liner that then was a shrink fit into your bored out hub And then after fitting you still needed to pin the liner to the hub it to stop it possible rotating in the wheel hub under heavy braking, as like I said originally the wheel hub was cast around the liner so very secure. So for me it was easier to just modify the original drum brake hub to accept to a disc brake set up Lastly just for info on the Honda forum a guy called Paul Jackson (an engineer based in Huddersfield) has replaced some cracked liners on old Hondas but not sure if he is still about but maybe worth a Google using his name and location? Best wishes Alan . I'd gladly pay the price. CMSNL list a wheel for 700 and odd euro , but they dont have any . And I thought crankshafts were expensive !!
Post by yamman1066 on Mar 10, 2023 20:27:53 GMT 1
hi, will be around 150 for a good 4l0 wheel
Post by bezzer on Mar 31, 2024 18:29:09 GMT 1
There’s a YouTube video of a guy who bores out the drum lining, and threads it internally, then makes a drum with the same thread externally, and screws it into the hub. Presumably it must be a left handed thread to ‘tighten’ itself against the rotational force of the wheel when the brake is applied.
Post by urbantangleweed on Apr 1, 2024 7:52:53 GMT 1
There’s a YouTube video of a guy who bores out the drum lining, and threads it internally, then makes a drum with the same thread externally, and screws it into the hub. Presumably it must be a left handed thread to ‘tighten’ itself against the rotational force of the wheel when the brake is applied. I found this:
