Post by midlifecrisisrd on Jan 6, 2023 17:43:00 GMT 1
Bought a new gen banshee left case for a future build and it would seem that the finally learned that if the chain snaps it wipes out the top crank case and made the side case with a protector in it Pity they didn't do this earlier Steve
Post by Yogi on Jan 6, 2023 18:01:34 GMT 1
Sweet idea, where do you get them 👌
Post by midlifecrisisrd on Jan 6, 2023 18:03:43 GMT 1
Sweet idea, where do you get them 👌 Ordered it from Japan Guess how much 🤔 Steve
Post by midlifecrisisrd on Jan 6, 2023 18:06:00 GMT 1
There is also a rubber gasket (extra fiver) that seals the case onto the crank cases
Post by Yogi on Jan 6, 2023 18:16:33 GMT 1
Tooo much
I’ve seen a used one with gasket from the states for about £90ish if memory serves 🤔
Post by midlifecrisisrd on Jan 6, 2023 18:21:00 GMT 1
Tooo much I’ve seen a used one with gasket from the states for about £90ish if memory serves 🤔 £34 + post (Bought other stuff) 😁 Steve
Post by Yogi on Jan 6, 2023 18:39:15 GMT 1
That’s a bargaroonie 🤩
Post by bare on Jan 6, 2023 19:06:41 GMT 1
Erm .. looks to be plastic ? Not a helluvalot better if so.
Post by midlifecrisisrd on Jan 6, 2023 19:47:04 GMT 1
Erm .. looks to be plastic ? Not a helluvalot better if so. The ypvs case was plastic anyway so no worse off Steve
Post by donkeychomp on Jan 6, 2023 22:25:38 GMT 1
Will that fit an LC? If so can you pop up a link please.
Post by midlifecrisisrd on Jan 6, 2023 23:12:22 GMT 1
Will that fit an LC? If so can you pop up a link please. Alex It will go on but may need a little trim at the top rear corner to clear an LC frame the same way a ypvs one does There is no hole for the bolt in line with the sprocket and I think one extra at the bottom Steve
Post by 4l04ever on Jan 7, 2023 11:35:23 GMT 1
Looks great. What is the part number?
Post by midlifecrisisrd on Jan 7, 2023 12:16:13 GMT 1
Looks great. What is the part number? 2GU-15411-00 - cover 2GU-15379-00 - seal (if you want one) Steve
Post by jon on Jan 7, 2023 12:24:39 GMT 1
ajh
Post by ajh on Jan 7, 2023 12:52:59 GMT 1
Looks great. What is the part number? 2GU-15411-00 - cover 2GU-15379-00 - seal (if you want one) Steve If you dont want your day spoiled, dont look at the price on fowlers (£224.77)
