Post by tonyd123 on Nov 21, 2022 16:21:27 GMT 1
Just curious what these brackets are for on the radiator cover?
Post by mouse on Nov 21, 2022 16:27:34 GMT 1
31k bellypan, i think
Mouse
Post by Yogi on Nov 21, 2022 16:46:07 GMT 1
As above there for belly pans on Lc2s 👍
Post by midlifecrisisrd on Nov 21, 2022 17:02:24 GMT 1
What they said 😁
On the lc2 it doesn't have the 2 screw on bits on the bottom corners
Tabs on the belly pan locate into the sides then 2 lower screws onto the frame and 2 front upper screws into the mounts you have highlighted
Post by donkeychomp on Nov 21, 2022 23:36:26 GMT 1
Oh...just curious about THAT. Had me worried for a moment.
Post by JonW on Nov 22, 2022 0:15:27 GMT 1
On the lc2 it doesn't have the 2 screw on bits on the bottom corners Steve This has always interested me... Why would they make a cover for the LC2 and then not fit some parts of it? Im wondering now if they were fitted on the JDM market bikes and not elsewhere or something. Its just weird that the rad covers are the same and the early bikes (ie those it was designed for) dont get to use all the bits...
Post by tonyd123 on Nov 22, 2022 9:22:59 GMT 1
Ahh, obvious when you think about it
Post by midlifecrisisrd on Nov 22, 2022 9:25:55 GMT 1
On the lc2 it doesn't have the 2 screw on bits on the bottom corners Steve This has always interested me... Why would they make a cover for the LC2 and then not fit some parts of it? Im wondering now if they were fitted on the JDM market bikes and not elsewhere or something. Its just weird that the rad covers are the same and the early bikes (ie those it was designed for) dont get to use all the bits... It's not that the lc2 didnt have the bits, it didn't need them. The belly pan replaced them as it covered them up Its only with the naked map bikes it needs the corners to cover up the cut outs that the belly pan connected into Steve
