Sky +
Feb 3, 2010 1:30:05 GMT 1
Post by nikfubar on Feb 3, 2010 1:30:05 GMT 1
Anyone know about sky + I wondered why the memory was always almost full the past couple of days, erased everything and I have less than half the memory available Tried the usual, unplug it but it's still the same. Pain in the arse with all the crap my missus records, anyone any ideas. Cheers Nick
Sky +
Feb 3, 2010 1:40:14 GMT 1
Post by nikfubar on Feb 3, 2010 1:40:14 GMT 1
Cheers Gaz But how the hell do I do that
Sky +
Feb 3, 2010 6:28:13 GMT 1
Post by stevebozzy on Feb 3, 2010 6:28:13 GMT 1
while you are on the subject i have got sky HD , but i cant see any difference in picture quality i have got a good telly ( sony bravia) whats wrong ?
steve
Sky +
Feb 3, 2010 16:02:13 GMT 1
Post by stevebozzy on Feb 3, 2010 16:02:13 GMT 1
while you are on the subject i have got sky HD , but i cant see any difference in picture quality i have got a good telly ( sony bravia) whats wrong ? steve ... you need to connect your tv to your hd box with a hd lead. hd will work on equipment that sends HD signals such as SKY HD/FREESAT HD or blue rays dvd players etc.. joking aside mate HD channels will only be good if you have a 1080i set up on the tv and a good hdmi lead between the two.... gaz thanks Gaz, i have got sky HD fitted by the proper sky bloke, i assume he did it all correctly, so maybe it is my eyes steve ps whats 1080 ?
Sky +
Feb 3, 2010 19:38:32 GMT 1
Post by carlos on Feb 3, 2010 19:38:32 GMT 1
What have you started Gaz?
The ariel output from my SKY+ HD box runs to the TV in the bedroom, normal TV channels are fine but the quality of Sky is really poor in the bedroom! Any ideas?
As for HD, watch something on Channel 4, then flick to 4HD, the difference should be massive!
Sky +
Feb 4, 2010 21:55:36 GMT 1
Post by nikfubar on Feb 4, 2010 21:55:36 GMT 1
Hi Gaz Thanks for this, gave it a go tonight but no joy Option 1, couldn't even find the installers menue. Option 2, Tried this but the indicator ring didn't flash so still the same. Option 3, Wouldn't know where to start Bugger
Sky +
Feb 5, 2010 0:05:03 GMT 1
Post by carlos on Feb 5, 2010 0:05:03 GMT 1
2 reasons.... poor coax used or the aerail signal is too high remove aerial to the sky box and see if the sky in the bedroom improves...if it is clear then refit the aerial..if it then goes crap then the aerial signal need to be cut down t=with an attenuator...if the aerail removed and sky is crap then poor coax or incorrect ends are likely. i do this as a job mate so comes 2nd nature to me... i stripped jazzy's system and sorted his and all rooms spot on...takes more than coax to do it correct a good spectrum pays dividends to "see" signals and the dB levels.... Ariel signal must be too high, unplug the ariel and the picture is perfect! There are a lot of funny booster type boxes in the loft, I'll try bypassing it to the bedroom! Thanks mate, you've probably just saved me 100 quid call out charge and a load of bull shit from someone trying to rob me
Sky +
Feb 5, 2010 10:38:40 GMT 1
Post by carlos on Feb 5, 2010 10:38:40 GMT 1
2 reasons.... poor coax used or the aerail signal is too high remove aerial to the sky box and see if the sky in the bedroom improves...if it is clear then refit the aerial..if it then goes crap then the aerial signal need to be cut down t=with an attenuator...if the aerail removed and sky is crap then poor coax or incorrect ends are likely. i do this as a job mate so comes 2nd nature to me... i stripped jazzy's system and sorted his and all rooms spot on...takes more than coax to do it correct a good spectrum pays dividends to "see" signals and the dB levels.... Ariel signal must be too high, unplug the ariel and the picture is perfect! There are a lot of funny booster type boxes in the loft, I'll try bypassing it to the bedroom! Thanks mate, you've probably just saved me 100 quid call out charge and a load of bull shit from someone trying to rob me The boxes in the loft boost the signal from the ariel twice! I would've never put a shit picture down to too powerful signal
Sky +
Feb 5, 2010 21:42:19 GMT 1
Post by nikfubar on Feb 5, 2010 21:42:19 GMT 1
Cheers Gaz But how the hell do I do that have you tried in the settings??? if not a new drive should be got for it.... new drives are not easy to do though.... i can help you go into a secret menu that should reset the box for you.... Gaz How do you get into this secret menu ? Cheers Nick
Sky +
Feb 5, 2010 23:08:08 GMT 1
Post by racerd on Feb 5, 2010 23:08:08 GMT 1
while you are on the subject i have got sky HD , but i cant see any difference in picture quality i have got a good telly ( sony bravia) whats wrong ? steve is your tv hd ready yup there is a difference in picture quality between standard definition (sd) and hd, changed the hdmi cable to a uprated one gold plated ends and braided outer cable on my ps3 and there is a difference in picture sharper, clearer got to do the same for my sky+hd box its got a 160gig hard drive but there is a terra bite one coming out soon think it is 500 gig hard drive
Sky +
Feb 9, 2010 16:38:30 GMT 1
Post by mellow on Feb 9, 2010 16:38:30 GMT 1
all this HD stuff means jack shit to my 3" black n white tv/radio with my poor eyesight ;D
