Post by vinze187 on Nov 21, 2005 11:40:32 GMT 1
as worked out on other thread (started this one as that ones turned funny lol) boring +2.5 oversize would give 375cc Is there any drawbacks too doing this? unrealiablity? Weak crank?
If it was okay to do are there any other mods that can be done to compliment it?
Post by hooligan on Nov 21, 2005 12:13:02 GMT 1
Hi Vinze
If its on a Valve your pistons will hit the powervalve and you would need to mod the head gasket. Mine are .2 over size and only just miss the valve.
Post by vinze187 on Nov 21, 2005 12:19:40 GMT 1
Cheers guess ill not do that then lol
have you come across any other problems with your size rebore?
Is it noticably different than from standard size?
Post by Norbo on Nov 21, 2005 14:17:12 GMT 1
The liner gets very thin and is more prone to sezurs becourse the barrel can and does go a little ovel ater time and more so when you are on a very big over size.
Post by vinze187 on Nov 22, 2005 9:18:24 GMT 1
Right i shant risk it! if i cant afford a big bor kit i'll not do it cheapy and end up with a load more problems
