Exhausts
Jul 14, 2022 14:52:51 GMT 1
via mobile
Post by seang14 on Jul 14, 2022 14:52:51 GMT 1
Hi Guys So I’ve just built up a 250LC, Bike came with a set of exhausts with 4L0-14711 Are these correct pipes for a 350 Bike also has 31W00 Carbs I believe to be from YPVS When I kick bike over it runs second kick and ticks over fine! When I Rev bike it seems bog down & Not Rev crisply, keen to take out on road but not until I’m sure I have correct pipes on? Will bike run ok with the PV Carbs
Any Advice would be much appreciated, keen to get out on the Bike when the Suns a Shining!!!🤪🤪
Cheers Sean G
Exhausts
Jul 14, 2022 14:54:22 GMT 1
via mobile
Post by seang14 on Jul 14, 2022 14:54:22 GMT 1
Hi Guys Sorry message should have read just built up 350LC!!
Cheers Sean G
Exhausts
Jul 14, 2022 15:18:49 GMT 1
via mobile
Post by midlifecrisisrd on Jul 14, 2022 15:18:49 GMT 1
Hi
250 and 350 pipes are marked 4L0
350 pipes have a 0 stamped on the rear mounting bracket
Only the number of holes in an internal baffle plate the won't cause your problem
31w are German restricted 350 ypvs carbs
Only jetting to match the restricted exhausts on the 31w
You will need to fit 27.5 pilot jets to get it to run correctly
Exhausts
Jul 14, 2022 15:20:06 GMT 1
via mobile
Post by midlifecrisisrd on Jul 14, 2022 15:20:06 GMT 1
250 lc pipes on a 350 will give more mid but less power up top
Exhausts
Jul 14, 2022 20:40:48 GMT 1
via mobile
Post by seang14 on Jul 14, 2022 20:40:48 GMT 1
Hi Steve So if I need to put 27.5 Pilot jets in Carbs what size main jets would you suggest? Cheers Sean G
Exhausts
Jul 14, 2022 21:00:48 GMT 1
via mobile
Post by midlifecrisisrd on Jul 14, 2022 21:00:48 GMT 1
Standard ypvs carbs are 240 mains
Post by 4l04ever on Jul 15, 2022 17:58:15 GMT 1
I run 31W carbs on an LC with 25 pilots fitted. Bike has Microns and modified airbox.
