Post by mak595 on May 24, 2022 16:17:20 GMT 1
Guys, is it possible for a stator to run a 31k PV engine ok but not charge the battery?
I've tested the white wires and coming back with 1.2 ohms which obviously is low but I tested my other 31k that's fine and that reads the same so I assume it's just my cheap meter reading low...
Post by midlifecrisisrd on May 24, 2022 16:20:59 GMT 1
Yes
Cdi source coils and charging coils are separate so can easily have one set working and one set not
Usually the voltage regulator is the first port of call or the plug with the 3 white wires is fried
Strve
Post by mak595 on May 24, 2022 16:53:35 GMT 1
Yes Cdi source coils and charging coils are separate so can easily have one set working and one set not Usually the voltage regulator is the first port of call or the plug with the 3 white wires is fried Strve Thanks Steve, It's running a ignitech unit so obviously I'm only concerned with the 3 white wires, I've tried another reg/rec and still not charging so I assume it must be the stator but just wanting a bit of confirmation before I look for another or rewind etc...
Post by midlifecrisisrd on May 24, 2022 16:55:30 GMT 1
Ignitech doesn't use the source coils anyway, just the pick up
You can check the voltage on the 3 white wires
Post by mak595 on May 24, 2022 17:00:33 GMT 1
Ignitech doesn't use the source coils anyway, just the pick up You can check the voltage on the 3 white wires Steve Ahh, I've only checked resistance, so I assume the whites would be 12v showing on meter?
Post by midlifecrisisrd on May 24, 2022 17:30:14 GMT 1
No, not 12v
It is unregulated and unrectified so will be AC and a lot higher
Figures should be in the manual for voltage at specific revs
