Post by 17again on May 22, 2022 11:04:40 GMT 1
looking at getting a replacement rear master cylinder for a ypvs does the brembo R6 one fit? or is the thread to short? mines rusted out thanks max
Post by midlifecrisisrd on May 22, 2022 12:03:27 GMT 1
The cylinder fits but as you say the threaded rod is too short
Buy the Brembo then get a stainless rod from norbo
Post by headcoats on May 22, 2022 15:51:39 GMT 1
rebuild kit comes with all those parts
Tourmax do a kit for about £24
Post by 17again on May 22, 2022 17:50:06 GMT 1
The cylinder fits but as you say the threaded rod is too short Buy the Brembo then get a stainless rod from norbo Steve so just checking the its only the threaded bar i change or the internals too?
Post by midlifecrisisrd on May 22, 2022 17:53:56 GMT 1
The cylinder fits but as you say the threaded rod is too short Buy the Brembo then get a stainless rod from norbo Steve so just checking the its only the threaded bar i change or the internals too? This bit Steve
Post by 17again on May 22, 2022 18:27:32 GMT 1
so just checking the its only the threaded bar i change or the internals too? This bit Steve perfect thanks steve.
