jam911
Post by jam911 on May 12, 2022 18:21:20 GMT 1
Post by steve h on May 12, 2022 18:26:07 GMT 1
All apologies. Never used it. I just put aspen in the tank when bike is laid up.
Post by midlifecrisisrd on May 12, 2022 19:16:04 GMT 1
Never heard of it
I just stick 50ml of oil in each tank full to stop any rust
Post by shaunthe2nd on May 12, 2022 19:50:07 GMT 1
Our biggest enemy is ethanol in fuel and it makes no mention of compensating for that.
Post by 29davyt on May 12, 2022 20:04:10 GMT 1
Thought you’d spelt post subject wrong and were asking about “ Seat Foam “ 😂
Post by stusco on May 12, 2022 20:04:22 GMT 1
My mate tried it in his carbs on his cb1000 as they were a bit gummed up it did jack shit!
rd84
Sea Foam
May 13, 2022 11:32:12 GMT 1
via mobile
Post by rd84 on May 13, 2022 11:32:12 GMT 1
All apologies. Never used it. I just put aspen in the tank when bike is laid up. Yes - works really well - no more problems since using it Cheers Paul
Post by markrd250lc on May 13, 2022 16:37:53 GMT 1
I used this in the Fazer 1000 that sat for two years and was really fluffy due to gummed carbs , worked great and i didnt have to strip the carbs just poured this in the tank, run the bike up a few times , now runs spot on .... the rest of the bike is a mess but it sounds good !! www.amazon.co.uk/Liqui-Moly-Carburetor-Valve-Cleaner/dp/B00VP5BVLQ
Post by bare on May 13, 2022 18:31:41 GMT 1
Seafoam is basically Kerosene.(yesss that's accurate.. spare me ) Spend large for the bespoke packaging .. IF you must.
Post by 4l04ever on May 13, 2022 19:22:46 GMT 1
You can just use Esso 99+ super unleaded fuel with no Ethanol in it. That should sort the issue...
Post by steeley on May 13, 2022 19:29:27 GMT 1
Seafoam is basically Kerosene.(yesss that's accurate.. spare me ) Spend large for the bespoke packaging .. IF you must. But is it ANY Gooooood . Just asking .
