Post by bezzer on May 7, 2022 11:48:18 GMT 1
Hi Chaps, Could any of you point me in the right direction to buy a replacement pulser coil for my 350 4L0 please?. I’ve checked on Fowler’s website, and it looks as if it’s only available on the NLA stator assembly. I’m also assuming this is the correct terminology as I’ve always called it a pick-up or trigger? 🙃.
As ever TIA, bezzer
Post by stusco on May 7, 2022 14:25:22 GMT 1
Im sure they are readily available try some of the companies that rewind the stators mine came with a new one when i got my lc2 rewound
Post by muttsnuts on May 7, 2022 15:28:25 GMT 1
ones for LC's not so easy to come by, never found anywhere that sells them, plentiful for the YPVS models, but they don't fit the LC stators and are incompatible
Post by bezzer on May 7, 2022 17:26:44 GMT 1
Thanks for your replies Stusco & Mutts, looks like the search is on for a ‘previously enjoyed’ unit then ☹️
Post by steeley on May 7, 2022 17:29:37 GMT 1
ones for LC's not so easy to come by, never found anywhere that sells them, plentiful for the YPVS models, but they don't fit the LC stators and are incompatible Hi, years ago i had a bolt from the stator back plate drop out and the pick up got damaged . I got in touch with a chap who did rewinds and he said he could repair it . Sent the stator and he repaired it . I would give you the chaps number but i think he has retired .
Post by bezzer on May 7, 2022 17:36:27 GMT 1
No worries Steeley, sadly these small businesses are falling by the wayside year on year, with no youngsters up and coming, or remotely interested to learn ‘niche’ skills. I live near Crewe, a town with a heritage of engineering (Rolls Royce, Crewe Locomotive works, midland Roller makers etc), where there were dozens of general engineers, plating shops, fabrication businesses at one time, now you’d struggle to get anything done!. Sad times.
Post by reedpete on May 7, 2022 18:07:36 GMT 1
I should imagine the guys that rewind the stators could rewind that, (unless the mechanics are damaged) . Not used them myself but think they called West Country windings.
FYI, that pickup is the same as the one in the AC 250/400 E/F
Post by muttsnuts on May 7, 2022 18:31:47 GMT 1
I should imagine the guys that rewind the stators could rewind that, (unless the mechanics are damaged) . Not used them myself but think they called West Country windings. FYI, that pickup is the same as the one in the AC 250/400 E/F it is Pete, the same as the 250/400 E/F, I know when I use to send stuff to West Country Windings they could repair the pickup, I assumed they rewound it, but not really sure, its a simple coil after all, but as with most things these days, the skills are being lost and fewer and fewer people are able to do this sort of thing I am actually speaking to a guy who winds his own stators etc about some of the ignition systems I make, I'll ask him about these as well
Post by bezzer on May 7, 2022 21:04:53 GMT 1
Thanks for the info Pete - every days a school day on here! 😁. And Dave, if your man can repair/rewind please keep us informed mate, although in this case mine is missing completely, so I don’t have one to send to him! 🙃.
Post by 4l04ever on May 8, 2022 19:48:50 GMT 1
You could remove one from a faulty stator. I have done that in the past to replace one of mine.
Post by oldelsieboy on May 8, 2022 20:37:29 GMT 1
bezzer I'm sure I have an old stator you can have, can't check till later in the week tho. OEB
Post by bezzer on May 9, 2022 13:14:37 GMT 1
Thank you OEB, I’d be very grateful if you do have one. More than happy to reimburse you for it too.
Post by jessy03 on May 9, 2022 18:25:07 GMT 1
I’m sure I have one somewhere you can have if OEB can’t find one👍 Jess
Post by bezzer on May 9, 2022 22:27:33 GMT 1
Thanks Jess, That’s very kind of you. I’ll wait until OEB has had a chance to look first, out of courtesy if that’s okay 👍🏻.
Cheers mate, Iain.
Post by 4l04ever on May 9, 2022 22:45:47 GMT 1
Bezzer, the bolt holding on the pickup coil was super tight on the one I removed, so expect a fight!
I fitted a nice stainless cap head screw after.. :-)
Post by bezzer on May 10, 2022 13:26:35 GMT 1
Thanks for the info Rob, mine is missing completely, so I don’t have that to contend with at least 😁. I’ll definitely be doing the stainless cap head mod though.
Thanks again buddy. Iain.
Post by oldelsieboy on May 11, 2022 21:16:35 GMT 1
Thank you OEB, I’d be very grateful if you do have one. More than happy to reimburse you for it too. Sorry bezzer, can't find the one I thought I had, must have binned it OEB
Post by bezzer on May 11, 2022 23:36:48 GMT 1
No worries OEB, thank you for looking anyway mate. With any luck Jess may have a spare he’ll sell 🤗.
Post by 4l04ever on May 12, 2022 21:19:06 GMT 1
If you don't get sorted, let me know. I have some faulty stators, but they are buried...
Post by jessy03 on May 13, 2022 18:26:54 GMT 1
Is this ok?, send me your address and I’ll put it in the post. Jess
Post by bezzer on May 14, 2022 1:26:56 GMT 1
🤗 Thanks Jessy P.M. sent bud!
Post by bezzer on May 20, 2022 19:45:35 GMT 1
Update: Coil is now sorted, after jessy03 very graciously sent me a spare he had. Without this forum and it’s fantastic members, I’m not sure this problem would have been resolved. Many thanks to everyone who offered help and advice, and especially to jessy03 for supplying the item.
Bezzer
